Author Topic: Silicone tip  (Read 3373 times)
Offline gazareth
Re: Silicone tip
« Reply #10 on: 01 August 2013, 00:39 »
but it might be a lot easier on the mk3?
Offline Screech16v
  • MK3 20vt AGU
Re: Silicone tip
« Reply #11 on: 11 August 2013, 18:36 »
Finally had a chance to fit the tip today, not sure about gains yet as I always struggle to tell the difference, maybe a little extra torque lower down, my 008 sounds different not as loud as before more of a hish than a ptssh lol,also had a few loud pops (backfire) out the exhaust when changing up is this to be expected?
« Last Edit: 11 August 2013, 18:43 by Screech16v »
Offline sharki786
  • GOT BOOST??
Re: Silicone tip
« Reply #12 on: 12 August 2013, 19:24 »
How did it go mate? Which tip you got?
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Screech16v
  • MK3 20vt AGU
Re: Silicone tip
« Reply #13 on: 12 August 2013, 20:39 »
Wasn't to bad to fit really,i turned a couple of alu top hat plugs for the two unused  take offs,it is an sfs tip.
Right I can now confirm that there is defo more power which is great,what is not so great is my boost seems to drop off more than ever in the higher revs down,from 0.8 to 0.4 bar,could this be a weak actuator spring causing this?
Also when I let off the throttle my engine wants to leap forward ,anyone got any info on this
Offline sharki786
  • GOT BOOST??
Re: Silicone tip
« Reply #14 on: 12 August 2013, 20:43 »
What dv u got? And what colour spring is inside it?
*****MK4 GTI T*****
Offline Screech16v
  • MK3 20vt AGU
Re: Silicone tip
« Reply #15 on: 12 August 2013, 20:43 »
008 yellow. This is now noticeably quieter aswell  :undecided:
« Last Edit: 12 August 2013, 21:16 by Screech16v »
Offline sharki786
  • GOT BOOST??
Re: Silicone tip
« Reply #16 on: 12 August 2013, 22:22 »
I cant say anything as mine is totally standard atm & i aint drove it far apart from at the garage (private land) and my turbo was making a fluttering noise :undecided: i got a dv007 with yellow spring to go on and s2k filter. Thinking about a forge tip aswell and a k03s.
*****MK4 GTI T*****
Offline Screech16v
  • MK3 20vt AGU
Re: Silicone tip
« Reply #17 on: 12 August 2013, 22:54 »
Mine used to make a flutter noise when my standard dv went awol
Offline sharki786
  • GOT BOOST??
Re: Silicone tip
« Reply #18 on: 12 August 2013, 23:05 »
Oh thats kool then as i got an awesome forge 007 here to replace the bosch on my agu. I just stripped it down and it has 4 parts to it, top and bottom covers, yellow spring and a piston. Is it ment to have something else?
Sorry hope you dont mind mate
*****MK4 GTI T*****
Offline Screech16v
  • MK3 20vt AGU
Re: Silicone tip
« Reply #19 on: 12 August 2013, 23:18 »
Get your own thread sharki, cluttering mine up with your crap lolz  :grin:
