Author Topic: R/v vac hose??  (Read 2958 times)
Offline 150+
R/v vac hose??
« on: 28 July 2013, 17:58 »
Anyone know where ican get the DV hose from, it's like 8mm one end and 4-5 maybe smaller at the other and now I've fitted a 007p it's not long enough
Offline dom
  • Back in a Mk4
Re: R/v vac hose??
« Reply #1 on: 28 July 2013, 18:20 »
The hose that does into the top of the DV is 4mm ID, I got mine from Auto Silicone Hoses :wink:
Offline 150+
Re: R/v vac hose??
« Reply #2 on: 28 July 2013, 18:49 »
Ok but the other end is bigger??
Offline dom
  • Back in a Mk4
Re: R/v vac hose??
« Reply #3 on: 28 July 2013, 18:53 »
It's 4mm ID all the way, if we're on about the same line it goes to a nipple on the underside of inlet manifold
Offline 150+
Re: R/v vac hose??
« Reply #4 on: 28 July 2013, 19:05 »
No the hose that comes off the top of the valve to the metal pipe just under the tip
Offline 150+
Re: R/v vac hose??
« Reply #5 on: 28 July 2013, 19:15 »
This hose
Offline dom
  • Back in a Mk4
Re: R/v vac hose??
« Reply #6 on: 28 July 2013, 20:06 »
On mine the hose from the top of the valve runs down to the inlet, the one from the side of the valve runs to the pipe you are referring to, I think that is 6mm ID, not 100% sure though.
Offline 150+
Re: R/v vac hose??
« Reply #7 on: 28 July 2013, 20:41 »
Any ideas as to why mine would run to the pipe in the bottom right of the pic I put ip
Offline 150+
Re: R/v vac hose??
« Reply #8 on: 28 July 2013, 20:42 »
It's a aum engine if that makes any diff
Offline dom
  • Back in a Mk4
Re: R/v vac hose??
« Reply #9 on: 28 July 2013, 21:13 »
No idea, mine is also AUM.
