Author Topic: Putting RCD310 back in......  (Read 3958 times)
Offline Keithuk
Re: Putting RCD310 back in......
« Reply #10 on: 28 July 2013, 01:07 »
I think the ecu only remembers one radio code. If you fitted an RCD510 then you should have entered the radio code for that one. If your putting back the RCD310 then you will have to enter the radio code for that one.
No they don't write the radio codes Cab's handbook if you don't have it then contact a dealer with proof of ownership and they should give it to you free of charge.
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline Ginge 35Edition
« Reply #11 on: 28 July 2013, 16:44 »
Plugged and played and the Sec Codes had been written in both manuals.
RCD510 now available - see classifieds.
Offline M3 SHAM
« Reply #12 on: 29 July 2013, 12:46 »
Cheers Neil, wonder what her parking sensor display will be like?
It does still have a parking display on the screen with LCD Markers from and back only as apposed to markers for each individual sensor.  Looks Naff in comparison to the RCD510 though, but better than nothing i suppose
Offline Raffe
« Reply #13 on: 29 July 2013, 16:40 »
Saw you have your rcd510 FR sale, do rcd310's have any value?
« Reply #14 on: 29 July 2013, 19:12 »
Probably about £50?
Offline M3 SHAM
« Reply #15 on: 30 July 2013, 11:41 »
Probably about £50?
I would say this is a fair value.  You got to remember the RCD 310 is still a good stereo when compared the standard equipment found on the entry level spec cars.  The 'S' spec or 'Bluemotion' spec have some very basic looking stereo's, the RCD 310 would at the very least freshen up the dash as it is double dim.
« Last Edit: 30 July 2013, 11:43 by M3 SHAM »
Offline Raffe
« Reply #16 on: 30 July 2013, 11:53 »
Thanks guys, will pop it an ad up for it then as will leave RCD510 in car when I sell it as I am lazy  :embarrassed:
