Author Topic: Putting RCD310 back in......  (Read 3966 times)
Offline Ginge 35Edition
« on: 27 July 2013, 17:49 »
Will I needs it's Security code or will it plug and play? I'm taking the RCD510 out before selling it.
Neil
Offline JoeGTI
Re: Putting RCD310 back in......
« Reply #1 on: 27 July 2013, 17:58 »
Plug and play.
« Reply #2 on: 27 July 2013, 18:20 »
Sweet cheers. I'm thinking about putting it in the wife's cab, I take it that the security code that i used for my install will be the same?
Offline Neil gti
« Reply #3 on: 27 July 2013, 18:25 »
Yes if going back in the same car it's plug n play
If 510 is going in another car it will be the same code as original install  :smiley:
Mk6 Gti Gone but not forgtten
Loving the 7R
« Reply #4 on: 27 July 2013, 18:40 »
Cheers Neil, wonder what her parking sensor display will be like?
Offline Neil gti
« Reply #5 on: 27 July 2013, 19:25 »
Not sure on the RCD ?
Should be ok, will just plug into one of the aux ports ?
Loving the 7R
Offline George k
« Reply #6 on: 27 July 2013, 19:30 »
You will need code for 310 as cluster will have code stored for 510
« Reply #7 on: 27 July 2013, 19:53 »
Thought it sounded too good to be true!
Offline Neil gti
« Reply #8 on: 27 July 2013, 20:52 »
The code for the 310 will be in the Cab,s handbook ?
Loving the 7R
Offline Buck
  • Das Auto
« Reply #9 on: 27 July 2013, 23:27 »
It should be plug and play as long as it has been in the car before. The code once entered is stored in the ECU.
If any problems, give vw a ring with the cars reg no. (That it was previously installed in) and after a couple of security questions they'll give you the code.
