Author Topic: HELP mk2 16v cut out problem  (Read 2643 times)
Offline GeordieChap
« on: 26 July 2013, 20:34 »
 Evening all
Have recently fitted new alternator, battery, isv, to my 89g 16v car is still up on axle stands and the engine was running ok but now seems to simply cutting out when the car gets to operating temp. When i go to restart the car its like there is no power in the battery to turn the starter motor but leave it 10mins and cars firers up! Just wondered if someone could point me in the right direction as is it fault battery, alternator or something else..
Offline Sgt_Lemon
  • 8v owners club
Re: HELP mk2 16v cut out problem
« Reply #1 on: 27 July 2013, 00:57 »
I don't know 16v's but it may be worth using a multimeter to check what the battery is putting out. What the alternator is putting out ect. Just to make sure the electrics are working as they should. The alternator may not be kicking in on idle and needs a rev to get going. Check electrics with multimeter and someone here who knows what they are on about should be able to help more.
Offline GeordieChap
« Reply #2 on: 30 July 2013, 15:26 »
Sorted it was the alternator have fitted a new one, no probs but the MFA aint working and has a load numbers in the display. Any ideas? It was a 65amp alternator fitted.
Offline Gambit
« Reply #3 on: 30 July 2013, 16:44 »
pull the fuse for it, and then stick it back in - it should reset it
just looking for interior lighting fuse irc
Offline GeordieChap
« Reply #4 on: 01 August 2013, 15:58 »
Cheers Gambit couldn't find the fuse so just disconnected battery and reconnected and goods a goodin
Offline GeordieChap
« Reply #5 on: 06 August 2013, 19:20 »
It's back! The battery is simply not getting any charge from the new alternator, think it could be the wiring loom from alternator to starter to battery, although I curious to know is there a earth from the alternator or does the alternator bracket and supporting arm work as the earth? If any one can help on the above its appreciated
Offline Sgt_Lemon
  • 8v owners club
« Reply #6 on: 07 August 2013, 10:39 »
Chek the blue exciter wire from the alternator. The often rot through within the rubber connector and it won't send the current to the battery.
Offline GeordieChap
« Reply #7 on: 12 August 2013, 21:07 »
Ok had wiring checked its all good so sent the new alternator back and got a replacement and its working spot on now, who would of thought a new alternator could be duff, cheers any way for the help and guidance
Offline GeordieChap
« Reply #8 on: 06 September 2013, 21:12 »
Just an update incase anyone runs into the same problem, so having fitted 2nd alternator after having tested the first one as faulty the problem of the battery going flat returned, so called in the sparky and the alternator wasn't earthing due to the fact I had had the alternator bracket and arm powder coated so scrapped the powder coating off around the bolt positions and jobs a goodin so if you any of you people powder coat your alternator arm expect the problem unless you scrap
