Author Topic: Mk 4 golf 1.8 turbo non start. PLEASE HELP!!!!!!  (Read 2363 times)
Offline richscriv
« on: 24 July 2013, 19:31 »
Hi this is my 1st post, I am in need of serious help guys, any ideas welcome. the story goes:
I started off with a 2002 golf 1.4 16v, I required a gti 1.8 turbo which was not in good condition, so my idea was to put the 1.8t in my 1.4 golf. I have swapped the:
engine
exhaust
ecu
wiring ect
when completing the car wouldn't start due to the immobiliser kicking in, I contacted VW dealer who said the keys need to be re-coded to the ECU.
I took the car to VW who then coded the keys in and the engine ran fine, and all drove fine.
after driving for about 10 mins, the engine cut out and wont start, it cranks but no start. when cranking theres no fuel froom the fuel pump, cant here the pump going, tried reading ecu with code reader, and is unable to communicate. I have checked fuses and all ok, I am stumped... the brief time it drove it drove fine, no warning lights ect all ok.
ANY IDEAS, PLEASE HELP, CHEERS
Offline dom
  • Back in a Mk4
Re: Mk 4 golf 1.8 turbo non start. PLEASE HELP!!!!!!
« Reply #1 on: 24 July 2013, 20:00 »
Can you hear the fuel pump prime when opening the drivers door?
You really need to get it scanned for codes, do you have an aftermarket head unit fitted?
Offline richscriv
« Reply #2 on: 24 July 2013, 20:07 »
hi, no I cant here the fuel pump when you open the door, I have a pioneer head unit in. its been in for about 4 years and given me no problem. ive had 2 different scanners on it and non of them can communicate with the ecu. both have worked fine in the past. cheers
Offline sharki786
  • GOT BOOST??
« Reply #3 on: 24 July 2013, 20:07 »
As dom says. Just turn the ignition on and have drivers door open and listen to a high whine moise (thays you fuel pump "priming", pushing fuel through) if you can hear it then should be a relay thats fooked and needs changing. Have you checked all of the fuses?
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline barrym381
« Reply #4 on: 24 July 2013, 20:09 »
Could be your ecu that's f**ked  :smiley:
Offline sharki786
  • GOT BOOST??
« Reply #5 on: 24 July 2013, 20:10 »
Posted just after you posted. Ok its going to be the relay or fuse
*****MK4 GTI T*****
Offline richscriv
« Reply #6 on: 24 July 2013, 20:22 »
ive checked all the fuses in the dash fuse box, haven't checked and relays, I find it weired that after all the work it drove fine for a short while and then cut out. I would have thought it would have had trouble from the start. does this sound major, do you know if there is some sort of master fuse that shuts down the ecu, but still allows the engine to crank, cheers guys
« Last Edit: 24 July 2013, 20:33 by richscriv »
Offline barrym381
« Reply #7 on: 24 July 2013, 20:39 »
My car would still turn over with a f**ked ecu  :smiley:
Offline james2
  • No scammers please.
« Reply #8 on: 24 July 2013, 20:40 »
I would check all wires / fuel pump. Did you use the 1.8 fuel pump. I wonder if you could use a external fuel pump, bet you can. I did it on a clan clover that ran 2 weber carbs.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline james2
« Reply #9 on: 24 July 2013, 20:44 »
Also check your getting a spark from plugs aswell .
