Author Topic: Mk 4 golf 1.8 turbo non start. PLEASE HELP!!!!!!  (Read 2359 times)
Offline richscriv
Re: Mk 4 golf 1.8 turbo non start. PLEASE HELP!!!!!!
« Reply #10 on: 24 July 2013, 21:09 »
I didn't use the fuel pump from the other car as I was told that the petrol engine fuel pumps are the same and produce the same fuel pressure, just find it strange that it did run and drive fine once everything swapped over
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #11 on: 24 July 2013, 21:16 »
you were told correct re the fuel pumps
Offline james2
  • No scammers please.
« Reply #12 on: 25 July 2013, 20:02 »
Check your crank sensor it controls the too things that on your car that do not work, new parts can fail.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
