Author Topic: Part Question  (Read 1521 times)
Offline Pez
  • Golf IV - 2.8 v6
Part Question
« on: 24 July 2013, 19:05 »
Anyone know where i can get a timing chain kit for a v6? Or know the price of one from VW (they're shut at the moment). Decided that the engine management light being illuminated and the sound of timing chain rattle isn't a good thing. On the up side i've been quoted £200+Vat for labour.
Offline barrym381
Re: Part Question
« Reply #1 on: 24 July 2013, 19:12 »
Tps mate an it's usually the tensioner that goes 1st on these,sure you can check with vagcom if the chain is stretched  :smiley:
Offline Pez
  • Golf IV - 2.8 v6
Re: Part Question
« Reply #2 on: 24 July 2013, 20:02 »
I got the code Crankshaft position sensor bank 2 P1347, that generally means the timing out? Do you know if the tensioner can be replaced fairly easily and if the tensioner would cause the timing to be out?
Re: Part Question
« Reply #3 on: 24 July 2013, 21:26 »
Seems cheap do they know how involved it is to replace it.
Offline damien010685
Re: Part Question
« Reply #4 on: 25 July 2013, 17:35 »
£200 + Vat i got quoted not far off a grand but it the end it wasnt the timing chain... Id be questioning that price as i know a guy with an r32 up here who did it and he diddnt see much change from a grand either... its a fair job as far as i know
Offline gazareth
Re: Part Question
« Reply #5 on: 25 July 2013, 17:55 »
is it not a gearbox out job as the chain is on clutch side?
Offline mike1990
Re: Part Question
« Reply #6 on: 25 July 2013, 18:19 »
The timing chain is normally on the opposite side of the clutch, the front of the engine
« Last Edit: 25 July 2013, 18:24 by mike1990 »
Offline barrym381
Re: Part Question
« Reply #7 on: 25 July 2013, 18:27 »
not on a mk4 v6  :wink:
Offline Pez
  • Golf IV - 2.8 v6
Re: Part Question
« Reply #8 on: 25 July 2013, 18:32 »
it's a mate of mine, he quoted me for 4 hours labour. He worked for an independent garage, then moved to working for halfords and now hes back at an independent. I told him it was a gearbox out job too..
Offline mike1990
Re: Part Question
« Reply #9 on: 25 July 2013, 18:38 »
Ahh, fair enough :)
