Author Topic: Too good to be true? K04  (Read 2219 times)
Offline Gary022
« on: 24 July 2013, 17:37 »
Just scrolling through ebay looking for any mods I require going cheap when I spyed this :
http://www.ebay.co.uk/itm/K04-Turbocharger-Turbo-Upgrade-VW-1-8T-20V-Bora-Golf-TT-A3-Skoda-Ocatavia-Seat-/370860130980?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5658fc82a4
Surely this can't be right cause as far as I'm aware upgrading to k04 is a relatively big job with all the supporting mods. The way this is advertised it's a straight bish bash bosh swap and ur away.
My guess is its either not going to give much performance benefits over the ko3s or it simply won't work without the mods needed like 3" maf and injectors or it won't fit at all haha.
What you guys think?
Mk4 Golf Gti 1.8T
Custom K&N CAI / Forge 008dv / 3" Turbo Back Exhaust with Highflow Sports Cat / Pressed Plates / Carbon Wrapped Interior Trim / 18" BBS CH Reps
Offline barrym381
Re: Too good to be true? K04
« Reply #1 on: 24 July 2013, 17:41 »
Looks like a cheap jap copy but I could be wrong but I still wouldn't stick it near my car  :smiley:
Offline topher
  • Administrator
  • fully functioning
« Reply #2 on: 24 July 2013, 18:52 »
I've tuned 2 cars with these on now.. first one hit a wall at 200bhp, next one 210 but that had a 3" exhaust the first was only 2.5"
keep saving buy a proper turbo!
Offline ben.banks21
« Reply #3 on: 24 July 2013, 18:57 »
nothing wrong in the cheapo copys, some making good power ask rtech and dynodaze.
Offline barrym381
« Reply #4 on: 24 July 2013, 19:01 »
Would you fit 1 to your car  :smiley:
Offline Gary022
« Reply #5 on: 24 July 2013, 19:50 »
Cheers for the feedback
Reckon once I'm finished with the cosmetics of my car  I'm going to go down the k04-001 route as I'm led to believe they bolt on instead of the ko3s without needing much of any modification. Seeing as I already have a 3" exhaust am I right in thinking a 3" maf  , Audi s3 injectors , Fmic and a remap is all i really need?
Mk4 Golf Gti 1.8T
Offline ben.banks21
« Reply #6 on: 24 July 2013, 19:53 »
ive got one. this one. :grin:
http://www.ebay.co.uk/itm/K03-KO3-REPLACEMENT-TURBO-CHARGER-1-8T-GOLF-GTI-98-05-/261237047296?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3cd2f10000
the only thing i did was change the actuator to a forge one
running 263bhp with WMI
Offline barrym381
« Reply #7 on: 24 July 2013, 20:15 »
That's decent power ad be happy with that   :smiley:
Offline Gary022
« Reply #8 on: 24 July 2013, 20:31 »
More research has revealed that there isn't much difference in the k04-001 and the ko3s :/
« Last Edit: 24 July 2013, 21:16 by Gary022 »
Mk4 Golf Gti 1.8T
Offline Scott D
« Reply #9 on: 25 July 2013, 00:07 »
there are differences between the two but not enough to warrent the cost of upgrading over a K03s based on experience having both turbos.
K04-001 seem to max out around 260-270 and K03s 240-250 without WMI, both make around the same amounts torque wise, given the cost of a geniune K04-001 it is a lot of money for 10-20bhp more something that a meth setup could do for a lot less on a K03s.
If changing turbo again I would much rather go for a good proven reliable hybrid than a K04-001
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
