Author Topic: What ET 8x17 on rear  (Read 4309 times)
Offline Diluxe
« on: 21 July 2013, 22:48 »
Considering 8x17 on rear , what ET would you guys recommend with 30mm drop on a vr6.
Cheer
1997 16V
Re: What ET 8x17 on rear
« Reply #1 on: 22 July 2013, 10:52 »
30 to 35 will be fine but you may need to trim the arches.
Offline Diluxe
« Reply #2 on: 22 July 2013, 11:04 »
If I kept the offset at ET43 , I 'd get an equal increase inwards or outwards, good idea or bad? I guess hitting the shock could become an issue.....
1997 16V
« Reply #3 on: 22 July 2013, 13:28 »
Yep it be very close to touching the shock.
Offline Len
« Reply #4 on: 23 July 2013, 13:12 »
Nah it wont! Only if you try and fit tyres bigger than 215 wide.
Standard offset is 45 which has lots of leeway
www.sas.org.uk
www.the-ace.org.uk
Offline Len
« Reply #5 on: 23 July 2013, 13:13 »
Oh btw unlike Wayne I have had a set of 8x17's on my car!
www.sas.org.uk
www.the-ace.org.uk
Offline Diluxe
« Reply #6 on: 23 July 2013, 13:24 »
what ET did you run?
1997 16V
« Reply #7 on: 23 July 2013, 13:40 »
I ran 7x17 with a 35mm offset on mine and it was tight for clearance.
You need to run 205/40/17's as well, 215's will throw the gearing / speedo out.
« Last Edit: 23 July 2013, 13:42 by Wayne »
Offline Len
« Reply #8 on: 24 July 2013, 13:06 »
Wrong again Wayne. :rolleyes:
215/40's are fine. Check the Wheel/Tyre info up above.
I think they were standard ET but I will look at the wheels and check for you.
www.sas.org.uk
www.the-ace.org.uk
Offline Len
« Reply #9 on: 24 July 2013, 13:07 »
I also ran the same tyres on a set of 7.5x17's which they are still fitted to and in my possession.
www.sas.org.uk
www.the-ace.org.uk
