Author Topic: Someone with vagcom needed (hinckley area)  (Read 9709 times)
Offline luke
  • When in doubt, whip it out!
« on: 20 July 2013, 18:30 »
After someone with vagcom to come figure out what's wrong with my car possibly tomorrow, will pay for fuel and beer tokens
1985 mk2 gti type 19 8v
2018 t roc sel 1.6tdi
Offline Rhyso
Re: Someone with vagcom needed (hinckley area)
« Reply #1 on: 21 July 2013, 00:36 »
Urm you have R-Tech on your doorstep.......... :rolleyes:
Offline JC
  • Back in the North.
« Reply #2 on: 21 July 2013, 00:39 »
And a vagcom section to ask in  :whistle:
Offline luke
« Reply #3 on: 21 July 2013, 00:45 »
And a car that doesn't start  :cry:
Offline Rhyso
« Reply #4 on: 21 July 2013, 10:46 »
Check your battery and fuses
Does it try to turn over at all?
Offline luke
« Reply #5 on: 21 July 2013, 12:01 »
Checked all the fuses, it keeps blowing the fuel pump relay, replaced relay fuse board and fuses, fitted an airbox as it had a rubbish induction kit, changed ignition switch, checked crank sensor which is working, changed battery, it try's, it ran yesterday then took oil cap off which made it cut out, checked the fuel outlet pipe and no fuel coming through, was going to replace fuel pump but they've sent me the wrong one, going to take fuel pump out and check it over
Offline golfyste
  • Project track car
« Reply #6 on: 22 July 2013, 17:08 »
Ring r-tech arrange a time and get it towed?
Offline luke
« Reply #7 on: 22 July 2013, 17:56 »
Tried calling a few times, going to tow it to work tomorrow and let the garage next door sort it out
