Author Topic: alarm  (Read 2554 times)
Offline jonesltd
  • MK7 R
alarm
« on: 19 July 2013, 17:40 »
How come my gtd only flashes not makes a sound?
If you cant find it......Grind it
Offline mike.
Re: alarm
« Reply #1 on: 19 July 2013, 17:54 »
You need to get someone with VCDS to turn it on. The beep is off by default in the UK.
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline Jimble
Re: alarm
« Reply #2 on: 19 July 2013, 18:46 »
Hang on, do you mean it only flashes when the alarm goes off or when you lock it? If it's the former then you have a fault so should get it inspected.
Offline Snoopy
  • Moderator
  • Geoff.
Re: alarm
« Reply #3 on: 19 July 2013, 22:07 »
If its just flashing when the alarm goes off its a faulty siren. Known issue. Mine failed and had to be replaced. There's a thread about it somewere on here by me.
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline Buck
  • Das Auto
Re: alarm
« Reply #4 on: 20 July 2013, 21:26 »
As Snoopy says. Mine failed too. Replaced under warranty.
Offline Keithuk
Re: alarm
« Reply #5 on: 21 July 2013, 01:58 »
My GTD flashes once when you turn it on and three times when you turn it off. I don't want the noise when you arm it as already mentioned you can turn this feature on with VCDS.
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline andyr
Re: alarm
« Reply #6 on: 21 July 2013, 10:03 »
My alarm sounder was also replaced under warranty.... I had no idea it was faulty!
Although they forgot to clear the fault log afterwards... Tsk...
Mk VI Black Pearl GTD.... No Frills, replaced a Black Pearl PD150 Bora, which in turn replaced a Dragon Green VR6 which followed a Dusty Mauve MK III 8v Gti.
Offline jonesltd
  • MK7 R
Re: alarm
« Reply #7 on: 29 July 2013, 13:42 »
Sorry for late reply went to Ireland! As for alarm once I lock it and something sets it off it just flashes that's it doesn't make noise. Its its a 59 reg so I guess its out of its warrenty?
Offline Snoopy
  • Moderator
  • Geoff.
Re: alarm
« Reply #8 on: 29 July 2013, 20:23 »
Mk6 GTI  &  Mk1 GTI
Offline scotland67
Re: alarm
« Reply #9 on: 30 July 2013, 09:43 »
Just found out my alarm only flashes the indicators, siren does not sound when tom tom sat nav fell off the dash and activated the alarm when the car was parked and locked. Sadly car is 3 months out of warranty.
The alarm might not have been working for a long time so it might be worthwhile for all you guys to test your alarm before the warranty runs out.
