Author Topic: The standard diverted valve  (Read 2697 times)
Offline GTi_James
Re: The standard diverted valve
« Reply #10 on: 17 July 2013, 16:12 »
watch the vid i just posted on the forum, gives you all the info you will need  :smug:
:grin: we are talking about the engine breather i think.  :laugh:
my bad the title said standard DV lol  :embarrassed:
Offline james2
  • No scammers please.
« Reply #11 on: 17 July 2013, 16:16 »
We are indeed could this valve being faulty cause total loss of boost?
No it's not pulling fine the car has no boost like a non turbo car.
If my car did this the engine breather thing would be the last thing i would look at . Its a boost leak , dv faulty, actuator on turbo stuck open or faulty n75 valve.
« Last Edit: 17 July 2013, 16:19 by james2 »
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline Scott-R
  • GoT BoosT!
« Reply #12 on: 17 July 2013, 16:26 »
But it's meant to be a one way valve and I can blow air through both ends and everything else I have recently checked (not to say there not faulty tho)
Just think my one way valve isn't one way ha
Golf GTI ... What else would you have?
Offline james2
« Reply #13 on: 17 July 2013, 16:38 »
im sure mines the same as i checked it after getting the car few years ago, last thing you want blocked but i was looking for wire mesh to clean inside it but there was none.  :huh:
Offline Scott D
« Reply #14 on: 17 July 2013, 19:06 »
one way check valve to prevent boost going into the PCV breather system.
I dont think a nackered hockey puck would prevent any boost. I'd be looking at downpipe and pipes to intercooler for huge leaks.
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline james2
« Reply #15 on: 17 July 2013, 19:38 »
There not known to fail ,you can clean them out with gunk and test it after by sucking through it , they get full of crap well mine was after 100,000 miles.  :evil:  I had to replace all the other pipes and connectors as they were leaking oil gunk and falling apart.  :whistle:
« Last Edit: 17 July 2013, 19:41 by james2 »
