Author Topic: The standard diverted valve  (Read 2698 times)
Offline Scott-R
  • GoT BoosT!
« on: 17 July 2013, 15:13 »
The black circular valve that sits on your intake pipe and connects to your rocker cover.
I took this valve off and it's no longer a one way valve think I mite have broken it ha
In my eyes this valve if broken would stop the engine from being able to boost up as its a boost leak?
Is this that important if this is broken could this stop my car from boosting up, the turbo is spooling but the boost is staying at 0.
Golf GTI ... What else would you have?
Offline Scott-R
  • GoT BoosT!
Re: The standard diverted valve
« Reply #1 on: 17 July 2013, 15:15 »
It's actually called the pressure regulator valve.
Offline james2
  • No scammers please.
« Reply #2 on: 17 July 2013, 15:28 »
my ones straight through. Well i think it is ,ill have to check it . :rolleyes:
« Last Edit: 17 July 2013, 15:31 by james2 »
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline Scott-R
  • GoT BoosT!
« Reply #3 on: 17 July 2013, 15:35 »
I thought the point of the valve was once the pressure gets up in the engine it slowly lets it out if it gets too high,, hence why the golf I'm looking at isn't getting any boost because its letting all the boost out?
Offline james2
« Reply #4 on: 17 July 2013, 15:58 »
Im not sure but hows the boost get in the engine, im not sure what the black thing does apart from letting the engine breath
Offline GTi_James
« Reply #5 on: 17 July 2013, 16:01 »
watch the vid i just posted on the forum, gives you all the info you will need  :smug:
Offline Scott-R
  • GoT BoosT!
« Reply #6 on: 17 July 2013, 16:04 »
I am on about the breather valve tho, could this valve cause loss of all boost?
Offline james2
« Reply #7 on: 17 July 2013, 16:05 »
:grin: we are talking about the engine breather i think.  :laugh:
Offline james2
« Reply #8 on: 17 July 2013, 16:10 »
i can not see this causeing 0 psi , does your car pull fine if so its proberly your boost gauge
Offline Scott-R
  • GoT BoosT!
« Reply #9 on: 17 July 2013, 16:11 »
We are indeed could this valve being faulty cause total loss of boost?
No it's not pulling fine the car has no boost like a non turbo car.
