Author Topic: Differences between CDA & DPA code 02A gearboxes?  (Read 7696 times)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
I'm currently collecting up parts for my 16v whilst I'm incapacitated with a broken shoulder,   one of the next main jobs that I want done is to have my new clutch and lightened flywheel fitted.
Seeing as the gearbox is coming off I thought it would be good idea to replace it with a lower mileage one seeing as they can be be picked very cheaply these days plus I could spruce it up with paint etc ready for a quick exchange.
I've just sourced  one  on ebay locally but it's a CDA code box,  IIRC mine is a DPA (need to double check tomorrow ). From what I understand they share the same ratios and the CDA was on earlier 16v's and fazed out after 96 and replaced with the DPA... What I'd like to know is why exactly,  are the DPA boxes more reliable,  did they change the oil capacity or something?
« Last Edit: 16 July 2013, 23:14 by thai-wronghorse »
Offline boneybradley
  • Back in a Mk3...
Re: Differences between CDA & DPA code 02A gearboxes?
« Reply #1 on: 17 July 2013, 11:40 »
I can't find that box code on the list I have... the early box is listed as a CGN fitted till 93 and then the CDA till 96
there's a list on my website with ratio's etc
http://boneybradley.webs.com/theenginesandgearboxes.htm
« Reply #2 on: 17 July 2013, 18:23 »
From what  I've learnt the DPA was used on cars after 96 like mine,  I'm just curious to know what the changes (if any) entailed?   :huh:
  • Back in a Mk3...
« Reply #3 on: 17 July 2013, 19:34 »
found it.... the dpa 02a is a seat ibiza abf powered (and mk2 i believe) box
Offline hobbiniho
« Reply #4 on: 17 July 2013, 20:40 »
they both have the exact same gear ratios i wouldnt worry about it i wouldnt think there would be anything different
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #5 on: 17 July 2013, 21:31 »
DPA is late othe ris early, no difference
i had a DPA off the 16v car, i ran this on my S3 engine till i upgraded to the 02J box and shifter set up
Not no ordinary GTI....
www.mixcloud.com/kells/
« Reply #6 on: 17 July 2013, 23:18 »
Cool,  that'll do for me then.  Cheers
Offline tshirt2k
  • Been there...Done that...
« Reply #7 on: 18 July 2013, 10:40 »
My recently rebuilt box is a DPA. And mine came standard with one on MY97 car.  There may be a slight difference. That would be the bottom bush underneath the shifter. They come in different sizes. And fitting an 02j may need the bush changing to match. Ratios are the same as mentioned.
Mk3 ABF 16VT Megasquirt V3
