Author Topic: Temperature gauge 130 (Max)  (Read 1964 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Temperature gauge 130 (Max)
« Reply #10 on: 17 July 2013, 20:19 »
and also this tells you what the nime mod is
http://www.nime.co.uk/content.php?mk4fans
« Last Edit: 17 July 2013, 20:21 by Wazzzer »
Offline james2
  • No scammers please.
« Reply #11 on: 17 July 2013, 20:43 »
Also replace your thermostat first as why did it go down to 70. When mine used to go down from 90 normal temp i took thermo out and put it in boiling water and it did not open. Strange as it must of alway been open.  :huh: If it shut it will over heat big time / it could just be faulty /common crap on most cars.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline lighters
Re: Temperature gauge 130 (Max) (STILL NOT WORKING)
« Reply #12 on: 21 July 2013, 14:10 »
I would check to see if fans work by unpluging the sensor on the radiator and bridging the plug with a wire ,if they work then its the temp sensor in the rad thats gone. This : http://compare.ebay.co.uk/like/141003935455?var=lv&var=sbar&_lwgsi=y&cbt=y&device=c&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0&ff12=67&ff13=80&ff14=66
My uncle bridged it over and the fans didnt work. What does that mean it could be?
It stays at 90c all the time but goes down to around 70ish when I had the blowers on hot at full. It also shot right up when it was overheating so im fairly sure the thermostat is working correctly?
Still waiting for a solution as the fans dont come on at all when ticking over.
Offline james2
« Reply #13 on: 21 July 2013, 14:39 »
i would remove the fan and test it on a bench with a 12v battery and see if it can be fixed ,if pop to a scrap yard to get another fan.
Offline lighters
« Reply #14 on: 21 July 2013, 14:57 »
How easy is it to remove and test?
Offline lighters
« Reply #15 on: 23 July 2013, 18:25 »
I managed to get it fixed for £20.
Basically the fuse had corroded away underneath and you couldnt tell from the top so they fitted a new wire and its not working correctly!
