Author Topic: GTI fuel rating (95 RON)  (Read 72285 times)
Offline Hawaii-Five-O
  • Are we nearly there yet?
« on: 14 July 2013, 11:33 »
Can some of our lucky forum members check what fuel rating the new GTI is supposed to use? I think there should be a sticker on the inside of the fuel filler door (it is on my Scirocco which says 95 RON).
In the GTI PDF brochure it says the fuel grade to use is 95 RON (minimum). However, as it says minimum, does this mean the engine is variable and could benefit from using 98 RON?
Current: BMW M140i / ZF8 / 5 DR
Past: MK7 GTI / DSG / WHITE / 5 DR
Offline GolfTi
  • ..gotta feel for my automobile..
Re: GTI fuel rating (95 RON)
« Reply #1 on: 14 July 2013, 11:35 »
95 on the filler cap.
I will try 97/98 on the next fill up to see if I notice any difference.
Mk7 GTI. DBP, DCC, Winter pack. Mine since new, July 2013.
GTI no. 4. Golf no. 5.  VW no. 7.
Offline barrym381
« Reply #2 on: 14 July 2013, 11:39 »
best running them on v-power  :wink:
« Reply #3 on: 14 July 2013, 11:51 »
Watch this and see if you change your mind on your octane rating :wink:
Stick with it, it's fascinating :nerd:
http://www.youtube.com/watch?v=D9nhXNarFdg
(Link courtesy of p3asa)
« Last Edit: 14 July 2013, 12:26 by Hawaii-Five-O »
Offline p3asa
« Reply #4 on: 14 July 2013, 12:14 »
And remember there is a part 2 also  :laugh:
It does make some interesting viewing though.
Offline Johnc41
« Reply #5 on: 14 July 2013, 12:23 »
The guy on the video makes total sense and you are wasting your money with anything more than 95. I agree I run 5 gti's on 99 then tried them all on 95. Made no difference whatsoever to driving or mileage, it's a complete waste of money.
Offline Bill_the_Bear
  • Yes! Wait a minute... No!
« Reply #6 on: 14 July 2013, 12:23 »
The new EA888 has variable cam timing and height.  From other things I've read I was lead to believe the higher octane fuels will have an effect on variable timing engines.  From the video I guess this might be because varying the cam timing will adjust the compression ratio at the point of ignition (and cam height adjusts the mixture?).  Can anyone confirm?
My main confusion is what is the mechanism the ECU uses to determine when to advance the timing?  In other words how does it detect/know that the fuel is different?  Presumably if your going to get better mpg then you need less fuel to be injected so how does the engine determine this?
Way back in my Chemistry A level I had to design a fuel which included maximising the octane while minimising the cost.  From what I recall it was a lot more complex than just adding mtbe or whatever it was he mentioned in the vid.  I'm wondering if in the US the fuel is not as complex.  The UK fuel 95 or 97/99 had maybe 5-10 different components IIRC.
« Last Edit: 14 July 2013, 12:26 by Bill_the_Bear »
« Reply #7 on: 14 July 2013, 12:24 »
Mk5 does not have variable timing.  Apples and oranges.
Offline Johnc41
« Reply #8 on: 14 July 2013, 12:27 »
I Had 4 mark 5 gti's and had them all remapped and the ed30 had over 300bhp and it made no difference whatsoever. It is complete and utter tosh.
Offline Johnc41
« Reply #9 on: 14 July 2013, 12:30 »
I also tried the same with my mk6 gti before remap and after remap, I even used asda petrol and it made no difference with fuel consumption or driving.
