Author Topic: quick question, is this worn?  (Read 1672 times)
Offline speedycoolboy
« on: 12 July 2013, 13:29 »
im curious because when the suspension on the car, is sits like this
Its on a mk2 golf, with coilovers
Thanks
« Last Edit: 12 July 2013, 13:42 by speedycoolboy »
Offline itavaltalainen
Re: quick question, is this worn?
« Reply #1 on: 12 July 2013, 20:44 »
can you put a photo on where one can see the full profile?
they normally 'sack' over time ... old ones being about 2cm shorter than new ones. from the gap on the second photo I would hazard a guess they are just on the edge... since you've taken the strut out might as well replace them... steering alignment is a lot more than those two strut mounts.
« Reply #2 on: 13 July 2013, 09:08 »
I don't have a photo, and i've just put them back on temporarily while the new top mounts come, and surely i dont need to do the steering alignment since  i've only altered the camber?
Thanks
« Last Edit: 13 July 2013, 10:21 by speedycoolboy »
« Reply #3 on: 14 July 2013, 21:10 »
if you've had it out and not marked it so it goes to exactly same spot (camber) then you've changed the geometry => alignment. the track rod ends probably won't need to be moved but camber will have to be adjusted.
