Author Topic: Why I didn't want to remove my plastic arches......  (Read 12716 times)
VW BUSH
Re: Why I didn't want to remove my plastic arches......
« Reply #20 on: 11 July 2013, 19:16 »
Patches under the sill trims make them sit funny and look blargh.
This will not be cheap to pay for.
Ask Murray to estimate the hours required to do this work properly and multiply it by 20 ph which is a fair rate.
It is a rare car and im not trying to put you off but a quick job will look gash
Gavv8
« Reply #21 on: 11 July 2013, 19:35 »
Even if it is an Anni i think thats past saving.. :sad:
Offline mrsaunders
« Reply #22 on: 11 July 2013, 20:02 »
its just surface rust don't worry  :wink:
Gavv8
« Reply #23 on: 11 July 2013, 20:19 »
Haha..yeah....thats rot....plain and simple.
Offline Foreveryoungaus16v
« Reply #24 on: 11 July 2013, 20:29 »
if i was you i'd take the rear bumper off, the side skirts off and then see what its like. If its rotten through there. then i'd personally sit down and have a think what i wanted to do with this car. That is alot of rust.
and if you really thinking about keeping it and giving it for a full respray. then do it once and get it done properly. at the end of the day it is an 16v anni.  :wink:
I know it looks bad, but im not going to find another mk3 without rusty arches under the trims, nevermind a 16v anni, im treated it as being part and parcel of being a mk3 owner, and like murraymint, once its done, it shouldn't need doing again.
Of course you would. None rust 16v are out there as I have one
163 BHP (TSR POWER RUN)
Offline gazareth
« Reply #25 on: 11 July 2013, 20:40 »
but maybe you have the only one :huh:
Offline gazareth
« Reply #26 on: 11 July 2013, 20:42 »
doh! how on earth did my sentence end up above the quotes?
« Reply #27 on: 11 July 2013, 20:44 »
Lol am sure there are quite a few. Just need to look hard and not rush into it
Offline murraymint
« Reply #28 on: 11 July 2013, 22:09 »
Took me 6 months to do mine ....... :rolleyes:
josh
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #29 on: 11 July 2013, 22:22 »
You often find in breakers the odd poverty spec mk3 with good arches. Cutting out the outer and a section of the inner arches and fabricate into yours. If done right it could remain invisible if thats what you want. I've done all this work to my last mk3 but used aftermarket repair panels and it was a far job to get right, albeit it was a more door. I jus scrapped a 92 vr6 with solid rears so they are out there. The early mk3's have slightly thicker steel at the arches.
