Author Topic: is it normal to lose mpg's  (Read 1854 times)
Offline welshdean
« on: 09 July 2013, 18:37 »
I've recently put on an s2000 filter and noticed the mpg has dropped to an average of around 23 mpg around town and when I was running the standard panel filter I was getting an average of 25-25 mpg.
Would the filter lower the mpg or should I start looking where the problem lies
Offline mcgee9t2
Re: is it normal to lose mpg's
« Reply #1 on: 09 July 2013, 19:20 »
cant see how it could lower the mpg. could be wrong though
could just be you driving harder?
Offline welshdean
« Reply #2 on: 09 July 2013, 21:15 »
Nothing more than usual mate. If my maf is f**ked would it be lower than this
Offline xxChrisxx
« Reply #3 on: 09 July 2013, 21:23 »
What's the point of the s2000 filter?
Offline welshdean
« Reply #4 on: 09 July 2013, 21:45 »
Because I'm a tart and like the sound and more so I can hear my dv  :kiss:
But it's too big to even use a heatshield properly as there is too much strain on all parts involved.
Everything on my car is standard apart from the dv, so I'm guessing I don't even need an s2000 size filter at the moment but just not sure of what other choices I have to give me the induction kit roar and the tshh from the dv
Offline xxChrisxx
« Reply #5 on: 09 July 2013, 21:57 »
As shocking as it may seem, you probably are flowing slightly more air for a given throttle position. Therefore burning the extra fuel. Probably doesn't account for all the loss of economy though, as 10% is a fair bit.
Running without a heat shield is probably not the best idea. It's unlikely to make anything go pop, but nice chilly air is the ticket ;)
There is one sure fire way to find out, stick a proper filter back on it and see what happens.
Offline GTi_James
« Reply #6 on: 10 July 2013, 13:47 »
+1 you have to be prepared for loss in fuel if you're adding bigger suckers on mate, more air+morespeed=morefuel  :cry:
Offline navmk4gti
« Reply #7 on: 10 July 2013, 22:09 »
Your booting it more wanting to hear the noise...hence more mpg :tongue:
Offline welshdean
« Reply #8 on: 10 July 2013, 22:16 »
Noise ? What noise?..... It's sh!t  :sad:
I've taken the heatshield off now anyway as it wouldn't sit properly onto the maf. So knowing my luck it will run like a bag of sh!te lol
Offline navmk4gti
« Reply #9 on: 10 July 2013, 22:33 »
Did you not just make the hole bigger for the heat shield .. you need to be a diy bodger with mk4s :grin:
