Author Topic: Is long life servicing a bad long term idea for the gti?!  (Read 1829 times)
Offline marty600
Hiya all,
As per my other post about engine flushing:
http://www.golfgtiforum.co.uk/index.php?topic=256507.0
Ie the old oil Ganges up the engine over time:
Dull performance
Poor mpg etc
Or should one simply just ask for engine flush when the car is next serviced?!
(is regular engine flushing bad?!)
Hope you can advise!  :smiley:
Martin
Offline itavaltalainen
Re: Is long life servicing a bad long term idea for the gti?!
« Reply #1 on: 07 July 2013, 11:03 »
just change your oil every 10k miles or once a year (whatever is earlier) and it will thank you for it. then you won't need an engine flush.
VW will also not use any engine flush stuff - not allowed by them.
Offline gazareth
« Reply #2 on: 07 July 2013, 13:20 »
engine flushes are a bad idea unless you plan on takes the sump of straight after to clean all the muck out.
