Author Topic: Rust????????????????  (Read 1789 times)
Offline kidhannn
« on: 12 August 2005, 16:43 »
Hi,
Have a mk1 which has started to show a bit of rust....
I noticed that most people replace the panels if any rust is displayed. Can re-spraying the car, does it make any difference if you use the same panels or new ones?
Offline ronnie'C'
  • MKVI GTi and a MK3 VR6 (lhd)
Re: Rust????????????????
« Reply #1 on: 12 August 2005, 20:49 »
As long as you traet the rust and make sure that it has all gone b4 you spray it you will be allright for a good while, if a proper job has been done.
Dinky
« Reply #2 on: 12 August 2005, 22:10 »
u talkin major rust?if so..then a new panel wud b better...but as 79ronnie has said..any rust shud b dealt with before the respray...u want any rust/dents/anything sorted before being primered n sprayed...
Dinx :kiss:
Offline BobbyT
« Reply #3 on: 13 August 2005, 21:36 »
i hate rust! had me doors done in feb but it is starting to come through again, i think they need re-skining! waaaaaaaaaaaaaaaa  :cry:
Offline richy_b
« Reply #4 on: 24 August 2005, 23:00 »
problem with rust is that the only real cure is to cut it right out, alot of people grind it down and try to get rid of it but unless you cut it right out it will continue to come back, its like cancer , cut it out befor it spreads!!!
thats why alot of spray shops wont give you a gaurantee on rust
