Author Topic: Finally fitting a sub  (Read 2993 times)
Offline Tazzy
« on: 03 July 2013, 21:24 »
its been many years since i last had a sub in the car, with 2 kids its not been practical, anyways, where is best in the bulk head to feed the power cable through and what side of the car is it best to feed it through?
edit: its a mk4 golf
cheers ta thanks very moochos
« Last Edit: 03 July 2013, 21:30 by Tazzy »
If It Comes Off, Modify It!
Offline 52GTIPETE
Re: Finally fitting a sub
« Reply #1 on: 06 July 2013, 07:29 »
Remove the glovebox. At the very top you will find a 10p size plastic grommet. You will have to remove your pollen filter and box in order to get access from the engine Bay Area.
Offline Tazzy
« Reply #2 on: 08 July 2013, 18:25 »
excellent, cheers
Offline Tazzy
« Reply #3 on: 12 July 2013, 18:34 »
well so far so well, power cable in, rca and remote cable in, just all need connecting up, need to go to halfords tomorrow for the little bits
wheres the best place to locate the earth to the body?
thanks  :cool:
Offline mad4vws
« Reply #4 on: 12 July 2013, 22:53 »
think there is a couple of stud under the rear bench with nuts on ?...
BREAKING VW GOLF'S
Mk2/ MK3'S ALL DAY LONG. PM FOR ANY PARTS!!  ON 07813936583
Offline 52GTIPETE
« Reply #5 on: 13 July 2013, 21:56 »
Depending on where your mounting the amp. I have always used the bolts to the rear light clusters. They always give a good earth.
