Author Topic: Chocolate cams.  (Read 4366 times)
Offline Granta Gti
Chocolate cams.
« on: 02 July 2013, 23:58 »
Got an 03 plate gt TDi with the chocolate can problem so need to replace the camshaft and bits, can some one tell me why it makes the induction noise so loud when this happens?
Offline Granta Gti
Re: Chocolate cams.
« Reply #1 on: 03 July 2013, 07:40 »
Had a thought overnight is it that the cam can't open the exhaust valve and when the inlet opens the exhaust gasses travel back up through the inlet ?
Offline gazareth
Re: Chocolate cams.
« Reply #2 on: 03 July 2013, 23:55 »
I think if the inlet valves are only opening a small amount it will increase the air velocity through them.
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Chocolate cams.
« Reply #3 on: 04 July 2013, 18:07 »
Offline Granta Gti
Re: Chocolate cams.
« Reply #4 on: 04 July 2013, 19:57 »
http://www.darksidedevelopments.co.uk/products/complete-camshaft-kit-for-1-9-8v-pd-engines.html
That is the kit you want. Far cheaper than VW.
Cheers scarr!
Although I think I have got a good deal, that lot
+ bolts
+ cambelt kit for £393 inc vat !
Only thing I don't have is the pulley removal tool.  :huh:
Offline scarr89
Re: Chocolate cams.
« Reply #5 on: 05 July 2013, 21:31 »
Cheers scarr!
+ bolts
Absolutely. When I do mine I won't need a cam belt kit as I did mine a short while ago.
Go to your local garage, see if you can borrow one. Or google one to 'hire'...are you DUY following a guide?
Offline gazareth
Re: Chocolate cams.
« Reply #6 on: 05 July 2013, 22:03 »
the quality of modern vw engines is just atrocious eh.
Offline Granta Gti
Re: Chocolate cams.
« Reply #7 on: 05 July 2013, 22:15 »
No I will just do it myself. I'm a mechanic so just like another job but not in the workshop ! Doing it for a trader and he is away for a week so might take the camshaft to work to take the pulley off.
Offline Granta Gti
Re: Chocolate cams.
« Reply #8 on: 14 July 2013, 01:42 »
Forgot to update on this one! Did the job last wknd and went really well 1 cam lobe was badly worn and one lifter was knackered with the rest showing signs of wear. I had to use a press to get the cam pulley off the old shaft. Car runs as it should now  :smiley: if anyone else has this problem let me know, always willing to help out.
