Author Topic: GTD oil temp What's yours  (Read 7513 times)
Marshy
« on: 02 July 2013, 18:28 »
As the title really just wondered what's normal.
My oil temp used to sit about 92 degrees after a 20 mile run
Lately it varies between 94-95 degrees and today after cruising on the motorway at 90mph for 5 miles it was showing 100 degrees
Offline najam90
Re: GTD oil temp What's yours
« Reply #1 on: 02 July 2013, 19:19 »
When I'm really flooring it it can get upto 112!  :laugh:
But normally it's showing around 97
Marshy
« Reply #2 on: 02 July 2013, 19:34 »
Oh that's reassuring
I was worrying when it was at 100.
When mine was at 92 maybe the outside temp was much lower then.
Thanks
Offline najam90
« Reply #3 on: 02 July 2013, 19:35 »
At the same time I do have a VERY heavy right foot, but normally anything in the low-mid 90's is fine
Offline ajmoir36
« Reply #4 on: 02 July 2013, 20:25 »
All sounds about right to me. 88degrees at a steady cruise of 58mph in 14 degree temps.
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Marshy
« Reply #5 on: 02 July 2013, 20:42 »
I usually travel at 80mph which usually sits 94 degrees so was slightly concerned to see 100!
Offline Candy Man
« Reply #6 on: 02 July 2013, 20:52 »
Can this be enabled with vcds, i dont think my gt tdi has
This feature, is it only gtis and gtds that have the gear
Change numbers on the mfd.
Marshy
« Reply #7 on: 02 July 2013, 20:56 »
If you have the same white display then I think the gearchange can be added via vcds I'm sure I've seen the option.
As for oil temp if you have the sensor in the bottom of the sump I'm sure it could be enabled too.
If you look in your engine measurements on vcds see if it reads oil temp.
Offline Candy Man
« Reply #8 on: 02 July 2013, 21:19 »
I have the full white display, i have viewed oil temps etc with vcds in the past, whilst messing about.
Our cupra had a similair clock display with the gear change info etc, i like these small extras  :smiley:
Offline Keithuk
« Reply #9 on: 04 July 2013, 03:02 »
I would think that would depend if you have an HighLine MFD.
I can choose what values I want showing on my MFD in the settings.
My oil temp is around 92°C cruising at 70mph. If I cruise at 100mph for a while then it goes up to 100°C.
It won't show any temperature reading until it reaches 50°C.
This digital gear indicator has been talked about before.
It would be nice to see your car spec in your signature?
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
