Author Topic: Who else hates the dentist?  (Read 5766 times)
Offline Shady Pioneer
  • graphic designer.
« on: 01 July 2013, 15:21 »
Because I sure do! Gotta go later today as may have an abscessed tooth! I really am not looking forward to it.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Who else hates the dentist?
« Reply #1 on: 01 July 2013, 15:25 »
Can't say im a fan either, I went in for a routine check up 2 weeks ago at my new surgery and ended up having root canal treatment as half my tooth snapped off whilst in there!  :sick:
  • graphic designer.
« Reply #2 on: 01 July 2013, 15:27 »
 :undecided:
I haven't been for several years, which is really bad I know, but I have such a phobia of the place. It's only now I have this throbbing pain in my mouth that I think I should go. It's been so long my dentist took me off the system!
I am literally cringing at the idea of going right now. An hour to go. FFS.
Offline Diamond Hell
  • Opinions я Us
« Reply #3 on: 01 July 2013, 15:32 »
I'm not the world's biggest fan and I have rubbish teeth, which doesn't help.
Wife has great teeth, loves going.
Wonder why?  :rolleyes:
Even so - it's worth going regularly to avoid things building up.
  • graphic designer.
« Reply #4 on: 01 July 2013, 15:34 »
This is what I've come to terms with. I've only myself to blame for this but nonetheless it's a scary place to me.
What I wouldn't give for good teeth.
Offline GOLF-MK3-GTI
« Reply #5 on: 01 July 2013, 15:37 »
I love going to the dentist, and i go every 6 months for check up.  :grin:
Offline Len
« Reply #6 on: 01 July 2013, 16:06 »
I love the Dentist too!
Anyway Shady if its just an abcess all they will do is give you antibiotics and tell you to come back in a couple of weeks.
www.sas.org.uk
www.the-ace.org.uk
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #7 on: 01 July 2013, 16:10 »
I'm not a fan, only go if i need teeth out but had a couple of white fillings at the beginning of the year. Had a couple of infected/abscessed teeth over the years. I know a very very good alternative remedy for sorting out the pressure pain associated with an abscessed tooth. It involves placing a damp swab dipped with salt and bi-carbonate of soda (half teaspoon of each) and placed between the cheek and gum next to the tooth. This will draw out the infected puss through the gum relieving  the pain and takes around 20 minutes to begin working. The only method of drainage the dentist will use is a drill, which on an abscessed tooth is nothing short of torture. They cant remove tooth until infection has cleared.
Offline dubber36
« Reply #8 on: 01 July 2013, 16:26 »
I don't like going. I had a piece break off a tooth years ago, but as it didn't hurt I didn't do anything about it until one day I bit on something and the hit the nerve, so I had to go. I turned up first thing without even ringing to make an appointment. He saw me straight away and put in a temporary filling and told me to go back in a couple of weeks. After around a month, the temporary filling was just starting to wear down. I quick google and I found that Boots sold DIY temporary filling kits, so I got one and kept patching it up myself...for 5 years.
Last year tho', enough was enough and I had to make an appointment as there was getting less and less tooth left to patch up. There was nothing for it but to take the tooth out. I'd heard all sorts of horror stories about extractions going wrong, but this one came straight out and I honestly didn't feel a thing.
I've needed a bit more work since as because I'd been avoiding chewing on the bad tooth for so long, I'd worn down the enamel on my front teeth. After working myself up into such an anxious state before, going to have this other work done was not quite as bad. I am determined to keep going and stay on top things before they get out of hand again. I still get worked up about going, but I find things like Rescue Remedy help no end as long as I does myself up a day or so before.
Offline MrBounce
  • Bora TDi 130 Highline - usually filthy.
« Reply #9 on: 01 July 2013, 16:32 »
I've had terrible teeth (apart from the front 12 which are near-perfect...). My other adult teeth never grew so am struggling with what remains of my upper ones whereas most of the lower jaw back are gone.
I blame the evil bar steward of a school dentist when I was at boarding school. He took one of mine out without anaesthetic. It's no wonder I have a fear of the dentist...
That said I do have a lovely dentist who I see every year. Must look after what I have got...  :embarrassed:
Keeping schtum. Mostly.
