Author Topic: One for the S2000 filter boys  (Read 24583 times)
Offline welshdean
Re: One for the S2000 filter boys
« Reply #50 on: 05 July 2013, 20:01 »
Hi guys, I've put my s2000 filter on today and only had a slight increase as far as the noise from the dv is concerned. Not really noticed anything different compared to a pipercross panel filter.
Also , I've attempted to put a heatshield around it and what a palava.
It doesn't fit properly because of the size of the cone.
I was wondering if I took off the heatshield, would I get heat soak or would it be fine ?
Has anybody run this filter without a heatshield on a standard maf on an agu engine and was it ok or did it create problems ?
Offline navmk4gti
« Reply #51 on: 05 July 2013, 22:05 »
Make the hole bigger on the heat shield thats what i did so fits im my 4mo :wink:
Personally i would not run it without it. The filter got very hot without it.. now it stays cool even after a propa blast :wink:
Offline welshdean
« Reply #52 on: 05 July 2013, 22:18 »
The hole fits my maf perfect, and I've trimmed down the silicone reducer in order to get the filter actually inside the vehicle LOL
But when I do up the two bolts that should secure the heatshield in place it puts a lot of stress on the maf. As in... Nothing settles without a fight. With the heatshield off its fine, but when everything is connected there's quite a bit of strain on each part, reducer, filter and maf because of the awkward angle .
Also the heatshield I'm testing out has got quite a big hole that caters for a cold feed pipe that's not connected at the moment and it's currently allowing warm air to come through .
If people have run it without heatshoeld and experienced no problem, I can take it off and make life easier
Offline dom
  • Back in a Mk4
« Reply #53 on: 05 July 2013, 22:25 »
Does the heatshield not have a crease in it? Mine does which allows it to bend, therefore eliminating stress on the maf.
Offline navmk4gti
« Reply #54 on: 05 July 2013, 22:29 »
+1 i bent my heat shield a bit so doesnt put stress on the maf and can handle vibration.did u buy the heatshield from that guy selling it in the classifieds by any chance with hole on the side :lipsrsealed:
Offline mattyfairbro240579
  • Nearly There With My 2.1 Stroker Build
« Reply #55 on: 06 July 2013, 00:09 »
Hi there buddy, where did you get that heat shield from ???
2000 1.8T R Tech remap - 310 bhp/321 lb;ft : Decat, stainless 2.5" exhaust, front mount intercooler, KO4 :  S2000 airfilter, Relentless manifold, Badger5 TIP, Saab red injectors, VR6 MAF housing, Forge 007p & Actuator, JK coilovers, Fully polybushed, Vibra Technics engine mounts, ECS Dogbone Mount, Cupra R fuel pump, TT subframe, Porsche 996 Calipers, HELL Lines, Custom 'J' Hook OE R32 Discs, Quaife ATB LSD,  Spec Stage 3+ Clutch & flywheel, WaterMeth, Rear ARB, AEM Data
« Reply #56 on: 06 July 2013, 00:13 »
god damn that car is fast. sorry to go off topic but jesussss!  :laugh:
Haha.... you talking about mine Dan lol  :grin:
Offline welshdean
« Reply #57 on: 06 July 2013, 03:02 »
I bought it from Nino , he should still have a pic of it on here somewhere
Offline xtetx
« Reply #58 on: 06 July 2013, 08:36 »
Hahaha yeah Matty, I want a KO4 so bad now!
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #59 on: 06 July 2013, 11:24 »
you've been out in it then mate lol
