Author Topic: One for the S2000 filter boys  (Read 24564 times)
Offline davemk4
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: One for the S2000 filter boys
« Reply #31 on: 02 July 2013, 20:57 »
Time to get my thinking cap on for a heatshield now...
Offline Turbo_T
« Reply #32 on: 02 July 2013, 20:57 »
1998 1.8t MK4 Gti golf
Offline pickles
  • Next!!!
« Reply #33 on: 02 July 2013, 21:09 »
is that attached to the MAF without a reducer?
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #34 on: 02 July 2013, 21:24 »
Yes, a VR6 MAF :wink:
Offline pickles
  • Next!!!
« Reply #35 on: 02 July 2013, 21:27 »
ahhhhhh  :whistle:
Mapped
Nearly S3 time  :)
Offline Dave_IOW
« Reply #36 on: 02 July 2013, 22:32 »
I'd have sprayed the filter black too Wes to keep it with the OEM theme :laugh::whistle:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
jamie16v
« Reply #37 on: 02 July 2013, 22:40 »
Offline mattyfairbro240579
  • Nearly There With My 2.1 Stroker Build
« Reply #38 on: 03 July 2013, 22:46 »
I've got a red / black s2000 filter, never fitted, £10 collected if anyone wants it. I know it's not classified but I'm sure someone wants it on here
I'll have it off you mate im only in warrington whats your address or number
2000 1.8T R Tech remap - 310 bhp/321 lb;ft : Decat, stainless 2.5" exhaust, front mount intercooler, KO4 :  S2000 airfilter, Relentless manifold, Badger5 TIP, Saab red injectors, VR6 MAF housing, Forge 007p & Actuator, JK coilovers, Fully polybushed, Vibra Technics engine mounts, ECS Dogbone Mount, Cupra R fuel pump, TT subframe, Porsche 996 Calipers, HELL Lines, Custom 'J' Hook OE R32 Discs, Quaife ATB LSD,  Spec Stage 3+ Clutch & flywheel, WaterMeth, Rear ARB, AEM Data
« Reply #39 on: 03 July 2013, 22:54 »
From what I can tell the red/black ones seem to be oiled where the green/white ones aren't
Hi mate, Matty here who bought Russ's candy white golf, how often do you need to replace the filter and do you no how long mines been on the white golf
