Author Topic: One for the S2000 filter boys  (Read 24559 times)
Offline Rylarr
Re: One for the S2000 filter boys
« Reply #20 on: 02 July 2013, 18:02 »
I've been looking all over the place trying to find a 86-70mm reducer but can't find any. I've read that a 80mm would do the job but will be very tight indeed.
Is it worth digging deeper to get the 86mm or will the 80mm be ok. As I've never held a s2k filter I don't know if I would end up breaking the connector end with brute force trying to squeeze an 80mm onto it.
more than likely end up braking it mate, there solid plastic :/
Offline paultownsend
« Reply #21 on: 02 July 2013, 18:02 »
JS performance. Ring up. Ask for 70-86mm silicone coupler.
Simples
Offline welshdean
« Reply #22 on: 02 July 2013, 18:05 »
Where did you buy yours from dom , and when you say trim it back.... Do you mean trim it down in the length or trim the inside so you could get the filter inside ?
jamie16v
« Reply #23 on: 02 July 2013, 18:12 »
Cut a bit off the end I would assume to make it shorter.
Offline Turbo_T
« Reply #24 on: 02 July 2013, 18:16 »
part number from ecp anyone ? :)
1998 1.8t MK4 Gti golf
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #25 on: 02 July 2013, 18:17 »
From what I can tell the red/black ones seem to be oiled where the green/white ones aren't
Offline dom
  • Back in a Mk4
« Reply #26 on: 02 July 2013, 18:29 »
I got this one:
http://www.ebay.co.uk/itm/290578527742?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
I trimmed some of the length off it, if I hadn't the filter wouldn't have fit inside the wing :grin:
Offline dom
  • Back in a Mk4
« Reply #27 on: 02 July 2013, 18:29 »
Mine is slightly oiled and is red/black :afro:
Offline xtetx
« Reply #28 on: 02 July 2013, 18:54 »
I've got a red / black s2000 filter, never fitted, £10 collected if anyone wants it. I know it's not classified but I'm sure someone wants it on here
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #29 on: 02 July 2013, 20:46 »
50260019J
