Author Topic: Catch can hose size  (Read 1695 times)
Offline 150+
Catch can hose size
« on: 30 June 2013, 17:11 »
Just got myself a catch can and wondered what size pipe I should be using??
jamie16v
Re: Catch can hose size
« Reply #1 on: 30 June 2013, 17:41 »
19mm I/D, but you'll need to alter the nipples on the catch can depending on which one you've bought
Offline 150+
« Reply #2 on: 01 July 2013, 08:28 »
Anybody know a good place to get these inlets from searched tinternet but couldn't find anything!!
What would you call them ??
Offline 150+
« Reply #3 on: 01 July 2013, 17:31 »
Right found the hose £5 a metre off fleabay but still can't find the nipples to replace the others.
Anybody have a link to where I can get some
Offline Jin_C
« Reply #4 on: 01 July 2013, 17:51 »
Have a look on eBay for 'BSP taper fitting' You will have to make sure the threads match though.
1.8T AGU, K03s, 007p, pipercross panel filter, G60 + VR6 clutch and flywheel, silicone TIP, decat + boost hoses, JOM coilovers
Offline 150+
« Reply #5 on: 01 July 2013, 17:56 »
Cheers mate!!
Nice to see someone local on here in only in wandsworth
jamie16v
« Reply #6 on: 01 July 2013, 18:06 »
I think it's:   1/2" bsp 19mm barbed
You want to be searching for  :undecided:
Offline Jin_C
« Reply #7 on: 01 July 2013, 22:42 »
Nice one, I'll have to keep an eye out. Just scrolled through and found a pic of your car from Wimbledon, is it still the same? Had another golf beeping at me near Clapham Junction a while back, wasn't you was it?
Offline 150+
« Reply #8 on: 02 July 2013, 13:39 »
No mot me!! I've now changed the wheels to calibra dubs in black
Back to the hose sizes...does it HAVE to be 19mm could I get away with smaller or slightly larger silicone hose??
jamie16v
« Reply #9 on: 02 July 2013, 13:42 »
why would you use larger silicone hose?.. it needs to be oil resistant too!
like this!
« Last Edit: 02 July 2013, 13:44 by jamie16v »
