Golf mk4
Wazzzer
Catch can hose size
Topic: Catch can hose size (Read 1707 times)
150+
GTI forum regular
Re: Catch can hose size
Reply #10 on:
02 July 2013, 13:51 »
The pipe I can find it the fittings I can't
Jin_C
GTI forum regular
Reply #11 on:
02 July 2013, 14:14 »
http://www.ebay.co.uk/itm/BRASS-BSP-Taper-x-Hosetail-Fitting-Connector-Fuel-Pipe-/250809147057?var=&hash=item3a6563deb1
Check out that item, if Jamie is correct you need to select 1/2" BSPT x 3/4" (19mm). However I have a feeling that the thread side (1/2" BSPT) would be too big.
19mm is ideal because that is the size of the pipe that comes out of the rocker cover. So there will be no restrictions in the system if you stick to that throughout. However saying that I have used all 19mm pipes and fitted reducers right before the pipes connect to the catch can input/output that are 15mm. Still works fine for me and collects a decent amount of water/oil
1.8T AGU, K03s, 007p, pipercross panel filter, G60 + VR6 clutch and flywheel, silicone TIP, decat + boost hoses, JOM coilovers
jamie16v
Guest
Reply #12 on:
02 July 2013, 15:36 »
Golf mk4
Wazzzer
Catch can hose size
