Author Topic: vr6 starting problem, wont crank  (Read 2822 times)
Offline aidan2112
« on: 29 June 2013, 19:53 »
My vr6 won't start, I turn the key and all lights still illuminate, but when turning to start it it doesn't even crank, battery is working fine, any ideas?
Offline spudboy6
  • Just like a golf ......
Re: vr6 starting problem, wont crank
« Reply #1 on: 29 June 2013, 20:24 »
Ignition switch
Try wobbling the key see if it disturbs the switch
Offline GOLF-MK3-GTI
« Reply #2 on: 29 June 2013, 21:28 »
Try wacking the starter, my gti did the same a few week ago
Offline Screech16v
  • MK3 20vt AGU
« Reply #3 on: 29 June 2013, 22:41 »
+1 for the switch.
Offline aidan2112
« Reply #4 on: 29 June 2013, 22:50 »
Got her going bump starting it, think the starter motors knackered, are they the same as an 8v ?
Offline aidan2112
« Reply #5 on: 29 June 2013, 23:46 »
Also tried wiggling the keys but no luck, RAC technician said its the starter motor, anyone got/know of one for sale?
Offline gazareth
« Reply #6 on: 30 June 2013, 01:50 »
try a direct live from battery+ to starter solenoid (thin wire terminal) try it a few times to be sure. and if it don't crank then your starters suspect.
« Last Edit: 30 June 2013, 01:59 by gazareth »
Offline benvictors
  • bgk Tuning - coming soon!!!
« Reply #7 on: 30 June 2013, 15:42 »
More then likely the battery, if theres not enough charge on it then it wont crank at all, try giving the battery a good charge first  :wink:
Offline gazareth
« Reply #8 on: 01 July 2013, 00:59 »
if the battery was flat the lights would go dim when you try to crank it over.
Offline aidan2112
« Reply #9 on: 01 July 2013, 17:17 »
Replaced the starter motor and still nothing, ever since ive had the car i noticed sometimes i would turn the key all the way but there was nothing, id have to take the key out and put it in again and then it would fire, would this be the switch?
