Author Topic: Passenger door has dropped.....  (Read 777 times)
Offline snifferdog
« on: 28 June 2013, 12:45 »
.....ok I think I have located the source of the wind noise/draft problem that Ive been having.
It seems as if the passenger door has dropped slightly and isnt sitting flush with the rubber door seal.
Its the top bracket/hinge that has play in it and is allowing the door to hang slightly lower.
My question is - how do I fix it? Is it a case of finding a replacement hinge or can I undo it/re-align it?
Thanks for your help guys.
jamie16v
Re: Passenger door has dropped.....
« Reply #1 on: 28 June 2013, 14:27 »
new hinge mate, some say you can do the pikey trick and put a jack under the door to bend it back, but it`ll only drop again :tongue:
Offline snifferdog
« Reply #2 on: 28 June 2013, 14:49 »
Cheers mate. I cant see how that would work though as it seems there is play in the top hinge as opposed to it being bent or anything.
