Author Topic: 007 forge dv problem  (Read 3018 times)
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
« on: 28 June 2013, 10:02 »
I have been thinking I have a boost leak for a while now because I keep getting 17705 and 17963 codes, but I have just had a smoke test and there are no leaks at all. It was suggested to me that it could be a weak spring in my Forge dv.
I am getting on average 190 bhp out of a remapped aum golf engine, but at times when driving in the higher gears fairly quick, I can feel it holding back, then it is as if something has jumped in to give it the extra boost. could this be the sign of a faulty spring in my Forge 007 DV?
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline Nino
Re: 007 forge dv problem
« Reply #1 on: 28 June 2013, 10:13 »
Sounds more like a faulty N75 to me mate. Btw have you done an N249 bypass?
Current - MK6 GTi Edition 35 - Candy White - 3 door
« Reply #2 on: 28 June 2013, 10:18 »
yes mate, I have done a N249 bypass. I only had a new N75 valve a year ago. It is strange because the boost is not there sometimes and then all of a sudden it kicks in, especially in 4th gear
Offline Nino
« Reply #3 on: 28 June 2013, 10:33 »
Sorry didn't read under your sig lol mine was doing this and it was my N75. Hmm does sounds strange if you recently changed it. The 17705 code is know. As a ghost code in the ecu on AUMs i too keep getting it. The other code it usally always related to the N75. Ok if this was me i would be checking the following.
Have you got anyone you could borrow there N75 from to test? Or I'd look to return yours and get a replacement.
Check all your pipes coming off the FR and all boost pipes coming/going to your inlet. Are your injector seals leaking? Is your rocker cover leaking oil? Your forge DV should have a yellow spring at a stage 1 map.
I know how frustrating this is I keep getting my 17705 and I have changed a lot...
*Bypasses the n249.
*changed TIP to silicone.
*changed all boost pipes to silicone.
*changed all inlet pipes to silicone.
*changed PCV pipes to silicone.
*changed DV for forge 007p.
*changed N75.
*changed charge pipe to AGU.
*cleaned TB.
*cleaned MAF.
The only other thing I can think of now for you would be your charge pipe if you still have the AUM one that will defo cause you a leak. As for me I plan on changing all my gaskets soon when I fit my chrome inlet and rocker lol
Offline Nino
« Reply #4 on: 28 June 2013, 10:34 »
Edit: just read your sig.  :whistle:
« Reply #5 on: 28 June 2013, 10:50 »
LOL  :laugh: I have also swapped the agu charge pipe hose that connects to the pancake pipe for a samco silicone one the other week, as there was a little leak there.
I have just phoned Forge and asked to buy a new spring for the DV. but the man said I probably didn't need it and is sending me out a service kit free of charge! Now that is first class customer service :smiley: and has save me spending £22. he suggested it is the O ring that may be the problem. So I will give it a go and report back here as soon as i have done it.
Thanks for your help though  :smiley:
« Reply #6 on: 28 June 2013, 10:52 »
What colour spring are you running in the Forge.
« Reply #7 on: 28 June 2013, 10:57 »
it is the right one as it is yellow mate  :smiley:
Offline Dalo Harkin
« Reply #8 on: 28 June 2013, 12:53 »
how long has the spring been in? I know they must last a while but surely they would get slack over time
Offline davemk4
« Reply #9 on: 28 June 2013, 13:23 »
Going to say my car drove 10x better with a forge setvice kit as it updates the design to a much better design. Mine holds more psi and for longer. Mine gave no error codes though
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
