Author Topic: 007 forge dv problem  (Read 3022 times)
Offline Nino
Re: 007 forge dv problem
« Reply #10 on: 28 June 2013, 14:00 »
I just rang forge they are sending me one for free too Sweeeeeeeeeeeeeeet!!!
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
« Reply #11 on: 29 June 2013, 06:20 »
how long has the spring been in? I know they must last a while but surely they would get slack over time
It is the original spring since I bought it about 2 years or so ago, could even be 3 years, I can't remember precisely
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
« Reply #12 on: 29 June 2013, 06:23 »
Going to say my car drove 10x better with a forge setvice kit as it updates the design to a much better design. Mine holds more psi and for longer. Mine gave no error codes though
Sometimes my boost gage wont go past 9 psi and then all of a sudden it kicks in up to 16 psi. Hopefully this service kit will sort it out!
« Reply #13 on: 29 June 2013, 06:24 »
 :smiley: cool!
« Reply #14 on: 02 July 2013, 09:08 »
Ok, I serviced my 007 DV, which does seem a bit better now, but I don't think that was the problem because it is still pretty much the same performance, although it is a bit better. I am awaiting on a new silicone TIP to arrive, because I think i have a small leak in it. It was just not picked up on the smoke test.
