Author Topic: Air filter  (Read 3192 times)
Offline jasonpi
Air filter
« on: 11 August 2005, 16:24 »
right apart from a serious oil issue all over the air box ive now discovered that my engines cutting out when idle or slowing down now i can rectify this problem by shaking the tube between the throttle body and air box :undecided: anyone now whats going on
its a 16v 89
Judderi
Re: Air filter
« Reply #1 on: 11 August 2005, 16:33 »
Have you also got oil all over the insides of your air box?
Offline jasonpi
Re: Air filter
« Reply #2 on: 11 August 2005, 16:34 »
aye took the middle tube out yesterday(was doing it before i did that) and noticed that oil was sitting in the tube and gromits
Judderi
Re: Air filter
« Reply #3 on: 11 August 2005, 16:36 »
What tube are you talking about? The one that goes across the front of the engine?
Offline jasonpi
Re: Air filter
« Reply #4 on: 11 August 2005, 16:37 »
the tube that connects the throttle body to the airbox
Offline jasonpi
Re: Air filter
« Reply #5 on: 11 August 2005, 16:43 »
oh and btw the smell of oil and petrol is quite strong if that helps
Offline monzablue16v
Re: Air filter
« Reply #6 on: 11 August 2005, 17:04 »
Sounds like you overfilled your oil dude it flows over the top and through all the air intake and kicks out big clouds of white smoke, U'll have to strip the air box and pipes give it a good clean and also the ISV will need cleaning could have done some engine damage as well although not sure what. also check for blockages in the pipe. good luck :)
Offline jasonpi
Re: Air filter
« Reply #7 on: 11 August 2005, 17:11 »
right good advice m8 one slight problem picked it up from gaz last week we reckoned it was a blockage noticed no oil in car yesterday so dont think its that filled it up yesterday aint checked yet but from the smell i can well imagine its still doing it. will give all the pipes a good clean over the weekend and btw idleing is sitting well over 1000rpm.
ISV dont know what that is what does it look like
Offline jasonpi
Re: Air filter
« Reply #8 on: 12 August 2005, 08:57 »
hello!!
Offline kniterider
  • had most, sold most and often buy more!
Re: Air filter
« Reply #9 on: 12 August 2005, 09:12 »
seems funny youve only had running probs since the 'kwikfit' people removed your airbox to do that brake pipe, im sure theyve split a hose or havent reconnected 1, it deffo sounds like a leak mate, as for the oil i dunno. get it running right before you look into the oil thing. i put money on it one of them spanner heads has f@cked something up.
