Author Topic: Air filter  (Read 2919 times)
Offline jasonpi
Re: Air filter
« Reply #20 on: 22 August 2005, 16:47 »
UPDATE: its working...
well this morning i thought i would give all the oil lines a good clean and isv to see if it idles good on a cold startup best test imo
well did that took the airbox apart and gave it a clean in soapy water :laugh: now couldnt afford to replace air filter as absolute no money yet but as i said cleaned all pipes and box in water dried it of hooked it all back up started it and at cold it runs at about 950-1000 well chuffed pulls really well now just need to replace the oil drenched air filter and should notice a vast imporovement!!
more to come looks like the rear suspension is fooked will have to think about upgrading  :cry:
need to remove dash as me being totally thick replaced the light switch for a gl 1 :huh: :huh: :huh:
you can guess what happened it didnt fit and i made it fit :huh: smoke fills the cockpit luckily enough did not catch fire will need to remove and see how much damage the wires has taken.
we all learn by our mistakes even when there so frigging stupid it makes u wanna cry
