Author Topic: Vag-Com (eBay) cable  (Read 25462 times)
jamie16v
Re: Vag-Com (eBay) cable
« Reply #10 on: 24 June 2013, 20:54 »
i've fixed the link, its in device manger
what he said, right click my computer > left click manage > when the window appears click device manager > ports usb/serial device (i think) and goto properties (i think)
cant really tell without the lead plugged in from the top of my head... :tongue:
Offline Ady TDI
« Reply #11 on: 27 June 2013, 08:07 »
Still no joy changing the letancy timer, oh well thanks anyway
Offline kr1s77
« Reply #12 on: 27 June 2013, 09:08 »
When I get home, I'll write up a lik guide.  What operating system are you using xp, vista or 7?
ASV 1.9 TDI 110
Offline kr1s77
« Reply #13 on: 27 June 2013, 11:42 »
this is for windows 7
Connect the cable to the laptop.
Right click on ‘my computer’,
Left click on ‘manage’,
Left click on ‘device manager’ (on the left hand side)
Left click on arrow for ‘Ports (COM & LPT)’
Right click on ‘USB serial Port (COM )’ (there will be a number after COM)
Left click on ‘properties’
Left click on ‘Port settings’
Left click ‘Advanced’
Latency Timer is in the BM Options select 12 (thats what i use)
Left click ‘OK’
Left click ‘OK’
ASV 1.9 TDI 110
Offline Ady TDI
« Reply #14 on: 27 June 2013, 13:22 »
Its an xp system  :wink:
Offline kr1s77
« Reply #15 on: 27 June 2013, 13:33 »
Right click on my computer
Left click properties
Left click hardware tab
Left click device manager
I think that should take you to device manager, its been a while since I used xp. Then carry on with the rest
ASV 1.9 TDI 110
Offline Ady TDI
« Reply #16 on: 02 July 2013, 08:09 »
Thanks mate, tried all that and still no communication, nevermind
Offline WadGTI
  • Golf GTI'er
« Reply #17 on: 02 July 2013, 11:16 »
Sorry, it may just be me...do you mean there is no communication at all when you try to select different ports in the test screen on vagcom?
Offline Ady TDI
« Reply #18 on: 02 July 2013, 12:37 »
I am able to check engine, HVAC and instruments, when I try to scan anything else being engine II, III, electrics, I get the communication failed message
Offline Rhyso
« Reply #19 on: 02 July 2013, 14:31 »
Probably because those modules aren't installed in your car  :whistle:
You can only communicate with stuff thats actually fitted
Dont forget VAGCOM is used across the VAG group and therefore other cars have more or less modules fitted
