The garage
Diagnostics - VagCom / VCDS
Rhyso
Vag-Com (eBay) cable
Topic: Vag-Com (eBay) cable (Read 25459 times)
Ady TDI
Here all the time
24 June 2013, 13:39 »
So as I am having a couple probs with the car, and I cant afford the real deal at the mo, I thought I would get this cable from ebay :
http://www.ebay.co.uk/itm/290930019045?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
After having trouble with the com port, I managed to get that working, I can scan the engine fine and for some reason it says no faults (my mate scanned with his snap on scanner and showed an EGR fault) my cable will also scan the radio, and instrument, but anything else I try and scan I get an "No response from controller" message
Anyone had this and know a fix ?
jamie16v
Guest
Re: Vag-Com (eBay) cable
24 June 2013, 13:45 »
try going to the options screen of vag com and put a buad of 9600 instead of 0 and click apply!
Ady TDI
Here all the time
24 June 2013, 14:03 »
Thanks Jamie will give it a try
Ady TDI
Here all the time
24 June 2013, 19:15 »
Nope that didn't fix it
Rhyso
Global Moderator
Sir Postalot
24 June 2013, 19:23 »
Clue could be in the fact its from Ebay and not a genuine lead..........
Fire Up The Quattro
jamie16v
Guest
24 June 2013, 19:51 »
Quote from: Rhyso on 24 June 2013, 19:23
very true, some work very well though!
luck of the draw when purchasing knock off`s!
Ady TDI
Here all the time
Reply #6 on:
24 June 2013, 19:58 »
SO true, least I got the fault I wanted that being my climate control
kr1s77
Here all the time
Reply #7 on:
24 June 2013, 20:03 »
this is what i did
http://www.ross-tech.com/vag-com/usb/FTDI-VCP-Options.png
Rosstech recomend latency timer of 2. Mines at 12 and works with mine when i got no response from my climate controller
P.S mines a ebay cable
Last Edit: 24 June 2013, 20:31 by kr1s77
ASV 1.9 TDI 110
Ady TDI
Here all the time
Reply #8 on:
24 June 2013, 20:15 »
Web page cant be found mate ?
Is the latency timer in options of vag com ?
kr1s77
Here all the time
Reply #9 on:
24 June 2013, 20:32 »
i've fixed the link, its in device manger
ASV 1.9 TDI 110
The garage
Rhyso
