Author Topic: jom coilovers rubbing?  (Read 1440 times)
Offline Wally989
« on: 23 June 2013, 18:22 »
Hello all,
I fitted my JOM coilovers at the weekend with the help of a couple of friends to get the old suspension off! (Very rusty and took a good few hours!).
They are as low as they go on the back which is 70mm which is fine with no rubbing. When I put the driverside down it rubs on the inside of the tire. So I have to have the coilover at the top which is 30mm lower than standard. I can lower the passenger front side with no rubbing.
Has anyone had this issue before? I think I need spacers to go down lower on the front. Any idea's or are spacers the way to go?
jamie16v
Re: jom coilovers rubbing?
« Reply #1 on: 23 June 2013, 18:40 »
what wheels and tyres are you using? perhaps use a 5-10 mm spacer?
Offline Wally989
« Reply #2 on: 23 June 2013, 18:50 »
They are skoda vrs alloys 16". Tyres are 205/55/R16 :)
Offline dom
  • Back in a Mk4
« Reply #3 on: 23 June 2013, 19:01 »
Common problem when lowering, a 5mm spacer will solve it.
Offline Wally989
« Reply #4 on: 23 June 2013, 19:06 »
If I get spacers I want to go out as far out as I can without tyres rubbing on the outside arch. Whats the biggest size spacers I can go for?
Offline dom
  • Back in a Mk4
« Reply #5 on: 23 June 2013, 19:11 »
Depends on the width and offset of the wheels?
Offline Wally989
« Reply #6 on: 23 June 2013, 19:26 »
How do I find out the width? the offset is 38  :smiley:
Offline Wally989
« Reply #7 on: 28 June 2013, 12:34 »
Got myself some 5mm spacers for the front and have put the coilovers down to 60mm and no rubbing!!
Sitting nice and lowwwwww now at 70mm on the back and 60mm on the front  :wink:
What do you think?
