Author Topic: Door Handle Question  (Read 2005 times)
Offline Rockey5uk2001
« on: 23 June 2013, 12:01 »
So my drivers side handle has been playing up
to sum it up you have to yank it to open it was planning on taking it apart over the next few days to have a poke around
anyone got any suggestions? or ideas?
Offline pickles
  • Next!!!
Re: Door Handle Question
« Reply #1 on: 23 June 2013, 12:11 »
sounds like your handle cable is a bit tight.
look here - http://forums.vwvortex.com/showthread.php?1015107
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
« Reply #2 on: 23 June 2013, 12:15 »
Thanks pickles
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #3 on: 23 June 2013, 14:34 »
Thanks pickles
Mine was doing that. That simple guide explains it all. Just make sure you don't undo the torx screw too much other wise it will fall into your door, which you will then have to take apart to get it!
« Reply #4 on: 23 June 2013, 16:53 »
fixed that problem now have 2 more  :angry:
First one - inside handle does not open the door!?!?!?!
Secondly -  When I open the door now the lock falls out!?!?!?!?
Help lol
Offline pickles
  • Next!!!
« Reply #5 on: 23 June 2013, 19:31 »
your little hook thingy will have came off, your gona have to get the door card off and put it back on.
did you tighten the retaining screw back up lol.
Mapped
Nearly S3 time  :)
« Reply #6 on: 23 June 2013, 19:44 »
Retaining screw tightened fully
Offline scarr89
« Reply #7 on: 23 June 2013, 19:51 »
That. The hook thingy will become extremely apparent when you remove the door card.
« Reply #8 on: 23 June 2013, 19:56 »
Looks like I'm striping the lock down tomborrow
« Reply #9 on: 25 June 2013, 18:39 »
so turns out the locking ring had came off,
tried to put it on and what a PITA that was!
Now the bit that locks the ring has sheared
so heres my question
could I delock it?
would that be a problem?
or can I buy a replacement ring? if so where from1?!
