Author Topic: How easy is it to fit a Milltek backbox yourself?  (Read 5177 times)
Offline tonyg123
hello guys,
im looking at buying a new backbox for myself, how easy is it to fit?
I have a 1.8T mk4 golf. not a pro but pretty confident with the tools
any help or ideas would be appreciated thanks :)
Offline Rockey5uk2001
Re: How easy is it to fit a Milltek backbox yourself?
« Reply #1 on: 23 June 2013, 11:42 »
ive never fitted an exhaust to a golf yet!
However I have done plenty on my mgzr similar shape
First step is to ensure the exhaust fits your valance Most websites will tell you if you need a new one and which
And generally its 2 bolts from the back box to the middle section - might take some WD-40 and a Breaker Bar
And slip the old exhaust of the rubber mount
To refit
Few tips get some exhaust paste to help form a seal
And I found washing up liquid helps slip the new exhaust back on the rubber mount
then bolt up and done
takes about an hour?
make sure u jack up the rear of the car and chock the front wheels and where possible use axel stands
Offline tonyg123
« Reply #2 on: 23 June 2013, 11:47 »
cheers,
sounds kind of an easy job then?
i have the 4motion valance fitted already, so just the fitting and im done!
Offline dom
  • Back in a Mk4
« Reply #3 on: 23 June 2013, 11:47 »
hello guys,
Just backbox or catback? Standard exhaust system is one piece from the cat so you'll have to replace it from the cat. This also means that you need to either cut the old system or drop the rear beam to remove it - cutting it is the easier option but that means you won't be able to refit it in the future.
Make sure you soak all nuts and joins in penetrating fluid beforehand and have a hammer and chisel close by. Depending on the condition of your existing rubbers it might be worth replacing them at the same time.
« Reply #4 on: 23 June 2013, 11:48 »
yeah it really is straight forward, just jack it up and check it out first look where the exhaust fits the biggest issue would be getting the bolts undone
if you think about what they go through
weather ect how hot and cold they get hence the breaker bar and WD40
Offline tonyg123
« Reply #5 on: 23 June 2013, 11:53 »
hello guys,
Hello Dom069,
should of said sorry, i am going with the catback option, does this mean much more work, also no ramp :(
Offline dom
  • Back in a Mk4
« Reply #6 on: 23 June 2013, 12:56 »
It's not too difficult, jack the car up as high as you can and support it with an axle stand at the rear of each sill and you should have enough access. I did mine ok like that and my coilovers are as low as they can go.
Use a small grinder to cut to old system close to the back box, remove the backbox first. Then you'll be able to remove the rest of the system from the cat without any issues.
Set aside a couple of hours start to finish :wink:
Offline tonyg123
« Reply #7 on: 23 June 2013, 17:39 »
Cheers buddy
thanks for the replies guys.
Offline chubbz1005
« Reply #8 on: 27 June 2013, 23:58 »
iv just fitted one yestrday the hardest part was getting the old one off fittings a piece of piss just remember to keep checking the backbox to make sure its straight as ur tightening it up
