Author Topic: Some kind of electrical fault  (Read 1480 times)
Offline Craigwilson
« on: 18 June 2013, 21:38 »
I have this Loss of power at 3000rpm if I'm driving and hold the revs there the rev counter jerks about a bit and the engine sort of dies for a split second and then continues, the car doesn't cut out atall and idles fine and runs good. Had a problem with the timing recently but it's all sorted now.
Note when my engines running the oil temp sits in the 90s but when I turn it off and put the ignition on it jumps down about 10 degrees then I start it and itl jump straight back up again with no delay, maybe thinking this could be related ?
Offline Joshp89
Re: Some kind of electrical fault
« Reply #1 on: 30 July 2013, 00:05 »
I'm having exactly the same problem! Help some one please its driving me nuts!! Thanks in advance and sorry for hi jacking the post  :smiley:
Offline Sgt_Lemon
  • 8v owners club
« Reply #2 on: 30 July 2013, 01:18 »
Is there a flat spot when going though that rev range in other gears?
