Author Topic: Golf 1.8T Decat for Jetex cat back  (Read 3180 times)
Offline westylakey
« on: 18 June 2013, 21:02 »
Hi, All I want to get a decat for my new Jetex system but don't know which one will go straight on?
Any help would be great ;)
2001 AUM 1.8T, Remap, Forge 008, AGU Charge Pipe, 3" Decat to 2.5" Jetex System, S2000 Filter Inc H/S
jamie16v
Re: Golf 1.8T Decat for Jetex cat back
« Reply #1 on: 18 June 2013, 21:08 »
what diameter is your jetex exhaust?
just buy one of the ebay ones and if it doesn't fit, get an adapter.
Offline davemk4
« Reply #2 on: 18 June 2013, 21:11 »
i too own a jetex system (i wonder if you too will have poor fitting issues??????? ) the decat as above you could get a ebay one and adaptor it together. i went custom with a proper flange welded to the jetex cat back and then a 3'' down pipe with flange with a drop in and drop out sports cat cost about £200 all in and fit and works a treat.
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline westylakey
« Reply #3 on: 18 June 2013, 22:46 »
I would assume mine is also 2.75"
jamie16v
« Reply #4 on: 18 June 2013, 23:01 »
where did you get 2.75" from mate?
Offline westylakey
« Reply #5 on: 19 June 2013, 05:49 »
Forums. But looking at the jetex website mine should be 2.5"
Offline dom
  • Back in a Mk4
« Reply #6 on: 19 June 2013, 11:03 »
I'd be very suprised it if it 2.75", most will be 2.5" with a reducer to bring it down to 2.25" where it joins the cat.
Offline cobalt6700
« Reply #7 on: 19 June 2013, 18:14 »
I chopped the 2.25" bit off my decat and had a bit of 2.5" welded on to meet my blueflame system  :smiley:
1993 GTI 8v 5dr matt black and green - the 'sh!tball rally car'
1997 GTI 8v 3dr metalic black - the daily driver
2002 3DR 1.8T AUM silver - the new daily
1993 Jeep cherokee 4L - the weapon :D
Offline westylakey
« Reply #8 on: 19 June 2013, 23:10 »
My jetex system is 2.5" and mates directly to the stock CAT, and was a perfect fit according to the fitter. So my question is what size is the stock cat so I know what decat my Jetex system will mate on too.
Offline dom
  • Back in a Mk4
« Reply #9 on: 20 June 2013, 10:32 »
Cat is 2.25", your jetex will be 2.5" until the end where it was reduce to 2.25" to join with the cat, same as the Milltek systems.
