Heres a run down:
When car gets really hot when approaching a junction, changing down gears, the revs plummet really quickly when clutch is pushed in - ONLY DOES IT WHEN IT IS REALLY HOT!!
New Thermostat fitted, new hall sender fitted, plugs, leads, cap and rotor arm fitted.
idle and CO adjusted?
Any ideas?
Its as if something which controls the drop in revs whent he clutch is depressed fails when if gets hot? Is there a sensor or switch that controls the drop in revs whn the clutch is pressed???
Any help appreciated as always!!
