It does say supplied with 2 extra springs, so open it up chances are there is a green one inside, you just unscrew the top to change the spring, so you can fit it to the car and run it see how it is, if needed put the yellow one in.
as you don't have a remap then the standard spring will be fine (presuming you open it and there is a green one inside)
