Author Topic: heavy clutch since vr6 clutch and g60 fly  (Read 2333 times)
Offline kingaz
« on: 12 June 2013, 22:35 »
Riggghhttt as some of u may remember i brought a clutch kit from techniclutch off ebay..
Anyway, since fitting the clutch is quite heavy..is this normal?
Also...its kind of like it takes two pushes to get it into gear.. best way i can explain it..
My mate said the clutch kit was wank, didnt have half the bolts.. he reckons the flywheel was 'unfinished' said there was no dowels and no top deadmarkkk.
Anyway..is the heavy clutch normal?
Az
Offline Granta Gti
Re: heavy clutch since vr6 clutch and g60 fly
« Reply #1 on: 12 June 2013, 22:58 »
Doesn't sounds right. That upgrade is meant to make it really light apparently. If it takes 2 pumps to get it into gear that sounds like the slave cylinder needs bleeding, did you disconnect the line or unbolt it.
Offline Granta Gti
« Reply #2 on: 12 June 2013, 22:59 »
Heavy clutch usually means a worn clutch plate.
Offline barrym381
« Reply #3 on: 12 June 2013, 23:11 »
Az
was it your mate that was fitting the clutch that said it was a pish kit  :undecided:
Offline kingaz
« Reply #4 on: 13 June 2013, 00:09 »
Not two pumps, more like 2 clicks of the gear stick to get it in... feels like it goes in to gesr in two stages..
Far as i know it was just unbolted...
Yeah my mate who fitted it said the kit is wank and he csnt see it bein a genuine sachs
Offline navmk4gti
« Reply #5 on: 13 June 2013, 00:20 »
The clutch should be very light. I remember when i fitted mine took me a bit to get used too defo no probs selecting gears etc tho. I would get another kit and give the one u got from techniclutch back
Offline barrym381
« Reply #6 on: 13 June 2013, 00:25 »
so if you trusted the guy to fit it why not listen to him when he said the kit was wank as you put it an get a decent 1 an most decent mechanics wont fit duff parts as in this case looks like he will be doing it again
Offline kingaz
« Reply #7 on: 13 June 2013, 01:29 »
Looks like it mate  :sad:
Offline davemk4
« Reply #8 on: 13 June 2013, 08:42 »
My techniclutch kit great really light pedal too
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline barrym381
« Reply #9 on: 13 June 2013, 10:16 »
well your to blame then if some1 sent you duff parts an you still got your mate to fit them  :laugh:
