Author Topic: oxygen sensor?  (Read 3261 times)
Offline nhop10
  • Mk3 GTi
oxygen sensor?
« on: 12 June 2013, 18:50 »
done a quick search but nothing. i had my car hooked up to vagcom today and came up with a few fault codes. one for an oxygen sensor? anyone know what this is and could it be causing my dodgey idling on start up?
cheers
Mk1 Golf 1.1, 6n Polo 16v, and now an 8v mk3 GTi
Offline ant_gti
  • mk3 20v turbo
Re: oxygen sensor?
« Reply #1 on: 12 June 2013, 18:55 »
oxygen sensor=lambda sensor its screwed into the cat  :smiley:
Offline nhop10
  • Mk3 GTi
Re: oxygen sensor?
« Reply #2 on: 12 June 2013, 22:47 »
cool cheers. so surely shouldnt have an effect on the starting and idling issues..
Offline itavaltalainen
Re: oxygen sensor?
« Reply #3 on: 12 June 2013, 23:16 »
which engine have you got, i.e. engine code (and don't come back saying a 2.0 8v)?
Offline madsb
Re: oxygen sensor?
« Reply #4 on: 13 June 2013, 09:04 »
Not the most likely reason for an uneven idle. Search for threads on this.
Offline nhop10
  • Mk3 GTi
Re: oxygen sensor?
« Reply #5 on: 13 June 2013, 22:22 »
AGG
Offline sharki786
  • GOT BOOST??
Re: oxygen sensor?
« Reply #6 on: 13 June 2013, 23:43 »
Lambda sensor will make the car hunt (bounching revs) been there :rolleyes:
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline nhop10
  • Mk3 GTi
Re: oxygen sensor?
« Reply #7 on: 14 June 2013, 22:39 »
are the lambda sensors the same on the 2litre and the vr6? mates got one breaking atm
Offline sharki786
  • GOT BOOST??
Re: oxygen sensor?
« Reply #8 on: 15 June 2013, 22:35 »
Not sure. You could always look on eurocarparts???
*****MK4 GTI T*****
Offline spudboy6
  • Just like a golf ......
Re: oxygen sensor?
« Reply #9 on: 16 June 2013, 23:56 »
Have checked and compared pt numbers and they do use the same sensor .
Lambda is constantly changing the mixture of air/fuel and of not reading correctly / working will give you a rough idle.  But more than likely its a dirty inlet / throttle as when a lambda sensor fails it will run a factory safe mode to the lambda to prevent over fueling and burning the cat out
