Author Topic: data logging, now looking good!  (Read 13860 times)
jamie16v
Re: data logging, now looking good!
« Reply #40 on: 23 June 2013, 13:11 »
course I would, you ain`t seen my arse! :smug:
Offline barrym381
« Reply #41 on: 23 June 2013, 13:12 »
thank f**k ave not mate  :grin:
jamie16v
« Reply #42 on: 23 June 2013, 13:15 »
don`t knock it `til you've tried it, 5 sessions and I would have enough for the custom map! :drool:
Offline Dave_IOW
« Reply #43 on: 23 June 2013, 13:42 »
Did your cat swap solve your 'cutting back' issue?
I had that on the mk4, seemed like MAF had hit limit and was sort of going into limp mode?
Release foot, wait a second, then you could plant it and be back at full boost again?
Mine was peaking at 22psi, but I was only running ko3s, on a ko3 map though.
Standard injectors and MAF though so I couldn't have been anywhere near 235hp/188 g/s?!
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
jamie16v
« Reply #44 on: 23 June 2013, 13:48 »
no mate, k04 in a k03 shell
Should hit good power with MAF and injectors mapped in then :afro:
hopefully yes, I remember nick saying something about pulling the timing a back at about 6krpm due to the lack of fuel, which was down to an old filter and pump. they are now upgraded too.
jamie16v
« Reply #45 on: 23 June 2013, 13:56 »
the cat swap improved it vastly I should say, I can still feel bit of a soft limit around 5.5-6k.
I am running standard maf and injectors on a k03s custom map.
it is peaking around 22-25psi but the N75 is doing its job and clipping it.
Offline Dave_IOW
« Reply #46 on: 23 June 2013, 14:01 »
Buggar, mine was running on one of those 3" systems with no cat, so that ain't going to be my issue then  :sad:
Mine used to cut back to about 4psi, in 3rd / 4th when about 5500rpm.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #47 on: 23 June 2013, 15:33 »
I thought your cam belt was a tooth out?
Offline Dave_IOW
« Reply #48 on: 23 June 2013, 17:59 »
It was, think that may have caused it?
Offline barrym381
« Reply #49 on: 23 June 2013, 20:10 »
:grin: :grin: bet your not kidding either
