Author Topic: data logging, now looking good!  (Read 13820 times)
jamie16v
Re: vag com data logging
« Reply #20 on: 12 June 2013, 23:35 »
i might stick the calibra injectors and vr6 maf in tomorrow and see how it runs, also fit the decat as looking at the symptoms, being cyl3 knocking first, it sounds exhaust gas temperature related.. :undecided:
Offline xxChrisxx
« Reply #21 on: 12 June 2013, 23:51 »
You are logging too many channels, you only have a very limited bandwidth and are getting a really poor sample rate as a result. Gotta pick your channels.
jamie16v
« Reply #22 on: 13 June 2013, 00:22 »
can you give an example of which ones i want to log?.
Offline paultownsend
« Reply #23 on: 13 June 2013, 10:49 »
did a quick log today. the only knock i got was 0.7 once on cylinder 3. who was it who mapped the car? is it a fresh tank of petrol?
Offline xxChrisxx
« Reply #24 on: 13 June 2013, 11:59 »
Can't help you there i'm afraid, it's just you are taking a log of load then a log of the knock approx 0.4 seconds later, which is a lot of rpm on a WOT run. Also it's about a second between MAF readings, so you can easily miss a peak or a dip in value.
You can still conclude that you've got a knock problem from the data you have captured.
jamie16v
« Reply #25 on: 13 June 2013, 12:33 »
i get you mate,  :wink:
Offline vwgolfv5
« Reply #26 on: 13 June 2013, 18:40 »
I use VCDS lite downloaded free from the Ross tech website. And a £7 ebay blue cable.
Seems to do everything I need but n75 duty.
I need to read up on the knocking and retarding logs. I don't quite understand it....
Sorry to hi-jack.
I have the exact same set up and I can not connect to the engine part. I know the cable works because I connected to the radio and a couple of other things, but not the engine.
Any ideas as to why ?
jamie16v
« Reply #27 on: 13 June 2013, 20:23 »
it was mapped correctly  :wink: mods have changed alot since.
jamie16v
« Reply #28 on: 14 June 2013, 17:22 »
i think i may have found the cause of knock.. i just went and swapped my cat over for the decat and when i unplugged the lambda sensor, the plug was full of water :shocked: it looks like the seal has gone  :tongue:
im not sure if this would be the cause.. but its one of my guesses.. the fact the old cat was fitted might have been a cause  :undecided:
jamie16v
« Reply #29 on: 14 June 2013, 19:36 »
looks like its fixed, swapped the restrictive cat for the decat and it looks like a gain of 11bhp since last RR (i had to stop due to fuel starvation in this logging session) so when theres plenty of fuel in the tank i`ll do another.
knock looks like its gone too  :smiley:
i will do another knock log because i think the last one i did, i think i missed the point where i was actually accelerating judging by the time stamp  :tongue: . not sure though
« Last Edit: 14 June 2013, 22:24 by jamie16v »
